Here is my shop built vacuum lifter, made in the fall of 2008, for lifting heavy objects onto a CNC router table.
The hose on the right, is a blow-gun for removing any chips or dirt
from the object you are picking up. ^
I put a rating of 500 pounds on this lifter, even though it will do more. ^
Main rails are made from two pieces of 1/4x2 cold rolled flat turned on end.
This allows you to move the vacuum cups, in or out, depending
on the length of the item you are lifting. ^
Drilling plates for the handles to bolt on. ^
Piab venturi vacuum generator, with a solenoid valve attached to the
back of it. Uses shop air to produce vacuum
of about 23" of mercury maximum.
This was something that come with our cnc router that we didn't use
so it worked out great for the lifter. ^
2x6 Aluminum rectangular tube was sawed on an angle to make the
switch and vacuum gauge boxes.
This was the first project , welding on aluminum
with the new to me, Miller Aerowave welder. ^
Final assembly in progress.
Check out the welding table, it come from the junkyard
as is, with tapped holes and the milled lines,and its 1/2" thick.
I seldom have to use a square with all those lines to gauge from.
Don't have a clue to what this bench was made for, sure makes one hell of
welding table though. ^
Drilling holes for the handle bolts on my 1960's 14x48 Clausing Lathe.
I rebuilt this lathe in 1997 (maybe another post on that?) ^
Switches for Up and Down on the hoist and On/Off for solenoid valve.
Cover is aluminum, milled out to slip over the rect. tube box. ^
Switches all wired up with 16-4 SO cord. ^
Vacuum gauge assembly.
I made the mount for this gauge, as it was not intended
to be a panel mount gauge. ^
Thats it for now
-John
!Don't have a clue to what this bench was made for, sure makes one hell of
Thats it for now
-John
