There has been some recent Craftsman Jack discussion here at GJ, So today i decided to tear down 1 of the 2 customer jacks i have in my shop. When the Customer brought his jack in i was at first puzzled when i seen that the tag referenced it as a 4 Ton Jack.. Here is the Link, You will notice it has a 1.5 star rating out of 74 reviews.. Hmmm...
http://www.sears.com/shc/s/p_10153_12605_00950156000P?keyword=4+ton+floor+jack&prdNo=2&blockNo=2&blockType=G2
After tearing into this jack my Puzzled feeling was quickly replaced with Concern. Ill let the Pictures do the talking, Above you will find 3 Piston style Ram cups. From Left to Right you have a 2 ton (Actually OLD 1 1/2 Walker size also) Walker/Lincoln Floor Jack Ram Cup, Next is the Sears "Professional" 4 ton Jack and Last but not least the Walker/Lincoln 4 ton Ram Cup. Do you see anything that looks ODD? If not a brief Non Engineering Degree explanation on what affects Tonnage. The Larger the Diameter of the Cup/Ram the More Tonnage it can handle, this rings true in all Hydraulic applications from Cylinders to Bottle Jacks to Floor Jacks. Still dont think this is a big deal? The Walker/Lincoln 4 ton Ram size is Nearly 35% bigger than the 4 ton Craftsman. I think this story goes alot deeper and is probably related to the Hp related fiasco Lawsuits that is hitting everyones door in regards to Lawn Mowers. In General People are Dumb and infactuated with Numbers. I can fix this jack as it has a Split Ucup but im not gonna touch it, The Design is too bad for me to even think about allowing someone to attempt to raise 8000lbs with this jack. I know that people are gonna come in here with there "If it wouldnt Lift 4 ton Sears couldnt sell it" My Response: Good Luck with That theory
