Lump
I've been buying lots of used tools lately, and I thought about cleaning the grease and crud off of some of them. For most of my life as a car hobbiest and home-project guy, I have relied on an old plastic bucket filled with kerosene to wash parts. But now I have been wondering about getting a parts washer with pump and proper chemical solution. I've always wanted one, like we used to have in the shop when I was turning wrenches for a living. Also, I have a couple of collector car projects which I need to get started on again soon, and it might be very convenient to have in that case.
This leaves me with several questions:
1) As a hobbiest, I know that any parts washer in my little garage will spend most of its time sitting there unused. So, can I get away with some cheapo imported unit? Will a used high-quality unit cost too much to buy for this application?
2) Where do you get the chemical...from the same seller? What if you buy a used high-quality unit, instead of a new one?
3) Is there any brand preference on the chemical?
4) How can you legally dispose of the used chemical? Is there ever any problem getting someone to accept it?
5) Under very-light usage, how long will the chemical last?
6) For an occasional user like me, with limited floor space...do you recommend having one of these units in my garage?
Thanks folks!!
Thanks folks!!
You're a pretty clever guy. You too, Ears. But tell me, how long have you used that submersible pond pump? I have a few of those in my pond in back yard, and I was under the impression that they would not hold up pumping anything stronger than water. But apparently not, huh? Wow.
