Hello! This is my first post here! I've been browsing the archives but although there's lots of compressor info, I couldn't find quite the answer I'm looking for.
I'm considering one of two compressors. Same seller, +/- same price. Both have 60 gal vertical tanks. The first is a Campbell Hausfeld VT627504AJ. 4 hp 240V motor, twin cyl cast iron (made in USA!) single-stage compressor. Splash lube. 10.2 cfm @ 90 psi, 11.5 cfm @ 40 psi. Looks like a reasonably well-built consumer-grade unit. About 4 years old.
The second is about 50 years old, Gilbarco with Quincy 310 compressor. Two stage, pressure lube, with 1.5 hp, 240V motor (newer than the rest of the unit, but still old). This thing looks very industrial and I'm sure will easily outlast me. Obviously very well built, and looks like reasonably well maintained (or at least not beaten to death).
What I have been unable to find, though, is apples-to-apples CFM numbers. The only thing I can seem to find about a Quincy 310 is that it's 4.06 CFM @ 400 RPM & 175 psi, and 9.35 CFM @ 920 RPM & 175 psi. 9.35 CFM is not that much less than 10.2 I suppose, but 90 psi is quite different than 175 psi so I've no idea what the Quincy would make at 90 psi (the CH wouldn't even be capable of 175 psi I suspect). I'm assuming the Quincy will produce more air, but how much? Any thoughts?
Thanks!!!
-c
Thanks!!!
-c
