Charles (in GA)
Ok, I stumbled onto some lighting on Ebay that is priced right and exactly what I had been looking at for some time.
It is like the two on the left in the pic. These are Acrylic reflectors that provide some uplighting to eliminate the "cave effect" and are 400 watt MH, 120V (only, not multi-tap) and draw 4 amps. I have seen these lights in several stores and in fact the seller told me these came out of a Sam's Club. My local Wally World had them until recently and switched to T8 flourescents.
These are "local" to me, about an hours drive, so no shipping, and I can get them, complete with bulbs for $40 each, which seems to be a bargain for a complete used MH fixture. From what I can tell, they are about 7 years old and are advertised as working when taken down.
My question is how many I might need. I have stood in stores and pondered this, but it is difficult to imagine what it would look like in my "shop", especially not knowing the wattage of the ones in the stores. As I have previously mentioned, my Shop, *** aircraft hangar, vehicle maintenance and storage garage, pesudo attic/basement, is a 60x60 metal building, 16 ft high eaves, 12/2 roof (21 ft at the peak) and it basically white inside as it has that white plastic backed insulation that is applied before the metal was screwed on the outside, and has exposed "red iron" and red oxide primed purlins. The lights will be mounted at about 14 ft, possibly a little higher nearer the middle of the building. It has 14 ft doors and doesn't make sense to allow anything to hang below 14 ft.
I've looked at the photometrics and attempted to use the Lithonia lighting software, Visual, but it was beyond me to figure it out.
From the photometrics, I'm thinking of doing three rows of four lights (a total of 12) this would put each light covering a 15ftx20 ft area, in theory. This is 48 amps, which will be spread out electrically as I plan to use three wire circuits powered by double pole ganged handle circuit breakers (two opposite phase hots which are actually 240v and a neutral), and use double pole heavy duty 30 amp Pass & Seymour switches (which I already have, bought them on a super clearance). Using three switches, this will allow me to put two fixtures across the A buss to the neutral and two across the B buss to the neutral, for each fixture. Sharing the neutral like this is legal, legimate and doesn't overload the neutral. Code does require the ganged double pole breaker however. Essentially the neutral won't carry any current as I am putting two 120v devices in series across 240V. You do this every day in your house and don't even realize it. (with even distributed loads on both sides of the panel, the neutral from the meter to your panel carries little or no current.
Anyhow, enough of the electrical lesson, what do those few of you who have shops with MH fixtures think of my proposed coverage, too much?, too little? I expect to still need a trouble light ocassionally for under hood work.
To me, it almost sounds like too much, at 5700+ watts the meter should spin right fast. The other possibility is to go with 9 light fixtures, each covering a 20x20 square in theory.
I also have four 250 watt MH low bay fixtures with metal reflectors and low bay light diffusers on the bottom I can employ, possibly over the corner where the workbenches and drill press/lathe/hydraulic press/parts washer reside.
I expect to go tomorrow and buy them, I'm off work and don't want to miss out.
Charles
Charles
