Lump
I asked this question before, at the tail end of an older post about Parts Washers. But I am in a bind right now, and REALLY need the advice of more-experienced Garage Journal members...as soon as possible, please. So I hope you will all forgive the redundant nature of this post.
Okay, yesterday I bought a cheapo 20-gallon parts washer from Harbor Freight, as a temporary solution until I can find and buy an affordable used Safety Kleen (or similar) unit. I had just stopped in at HF during an errand in the area, and just happened to catch their parts washers on sale (PLUS I took advantage of a Garage Journal member tip that I could get a 20% coupon if I asked persistently enough). So, my total cost was $71, plus I bought their extended warranty...in case I screw up the pump.
For that cost i could use it a few months, and throw it in the dumpster, and still be satisfied. I will use it very lightly. I'm just a hobbiest.
I assembled the parts washer last night, and now I'm ready to add my degreaser solution. I had originally planned to use mineral spirits. But right there in black and white on the instruction booklet it says to NOT use solvent-based solutions. RATS!
Now I am wondering whether that warning is just some lawyer-written "Cover-our-corporate-***" disclaimer copy, due to liability concerns about fire or "California toxicity" issues, or if it might be a legitimate warning because solvents will eat away at seals and other internal pump components? (I read a post on Garage Journal where someone claimed this pump is nothing but a fish-pond pump, intended for clear water).
Hence my question: Has anyone on Garage Journal bought and used one of these cheap HF Parts Washer units with Solvent-based degreasers?
And if so, how long did the pump last?
And some side questions...IF I slowly ruin the pump that came with this tank...are solvent-safe pumps readily available? If so, are they affordable? And, am I correct in assuming it will be no big deal to replace the cheapo HF pump with a different pump?
Thanks SO much for any help you can offer!!
