Air through PVC
Status
Not open for further replies.
gmhill33
Greetings,
Can you run air throughout your garage with PVC or do you have to use black iron pipe?
Thanks,
Gary
padronanniversary
Minesooooooota
I personally would not with PVC since it is not impact resistant and brittle compared to other offerings.
If you want simplicity, try the duratec line ...i.e. rapid air. Its fast, easy to run. Else run steel pipe or copper
TONE
Yeah theres more threads on this than photos of Jack O's place. Hard to imagine but its true.
G
gmhill33
I think I might just use the 3/4' black iron pipe with 1/2' drops. It will be about two weeks before I start installing it some I'm sure I will have more questions.
Thanks,
Gary
RbrtAWhyt
North East Georgia
Absolutely you can, many have done it and it is working fine for them and has for many, many years. But be prepared to be told of your impending death and dismemberment, be cursed at and spat upon by the "it'll kill you crowd", if you choose to do so...
nate379
Palmer, AK
Don't do it!
The PVC police will come over, beat your dog, **** your wife and daughter, eat all your cookies and drink your beer then burn your garage down.
I'm warning you....
:wtf::wtf::bounce::bounce:
mopar4wd
East of the river CT
I think the OSHA comment is interesting I worked in a shop a few years ago that was inspected by OSHA that had schedule 80 airlines going everywhere 2" mains with 1.5" drops probably had almost 800' feet of it they never said a thing. The company had a large engineering dept and the system was designed in house my a mechanical engineer. Don't know the model but it was hooked to a large Kaser screw compressor.
Stuart in MN
Minneapolis
If it was indeed PVC (there are some ABS pipes suitable for compressed air), the inspector and your mechanical engineer both dropped the ball.
ddawg16
S. California
And lets not forget that PVC is made from petrolum...so if you use PVC you are only enabling the likes of BP and middle east oil companies....
Charles (in GA)
50 mi south of Atlanta
While many may frown on OSHA and their rules, they have saved hundreds, if not thousands from various injuries or possibly death, with their rules and inspections. They are not perfect and sometimes the rules go overboard, but there is a reason for the rules, and like other safety devices like fire extinguishers, if you tend to follow the rules established for commercial businesses......... in your own shop, you have just added an extra level of safety to what you do.
The manufacturers of PVC pipe and fittings clearly state in their technical documentation that it is not intended for compressed GASSES, and this includes air. Any engineer who approves such an installation is not following the specifications of the manufacturer of the product.
Charles
Torque1st
MEMBER EMERITUS
KC Metro, Kansas
Use iron/steel pipe.
Even the PVC manufacturers forbid using PVC with air. They don't even allow leak testing with air. I am SURE they would market it for compressed air if it was even relatively safe just for the sales $$$.
tncatadjuster
Memphis, TN
I had PVC for a few years in my first shop. I never had a problem, but this was before the internet.
I now simply use a good quality air hose in place of the PVC, not as cheap and easy, also does not have the aesthetic that is required by a large number.
Hose works well for 12 years now.:thumbup:
Daniel Dudley
IIRC, PVC pipe is NOT designed or recommended for air line use. OTOH, God looks after fools and idiots, so if you feel like you are one of those types, go right ahead and use it.
Why any otherwise intelligent person would tell you it is fine is beyond me. It's kinda like the guys who tell you it is fine to dump motor oil on the ground near your well. Plenty of them here too. That doesn't make it right.
G
gmhill33
I can see that this is a sore subject with some. I have decided to us the Black iron pipe. Not as cheap or easy to use but safer in the long run (I'm sure).
Thanks,
Gary
Torque1st
MEMBER EMERITUS
KC Metro, Kansas
mad57
one word of advice .. when i did mine i bought homedepo black pipe well with new cutters and such and not my first time ... the pipe was junk oblong and ****** threads would cut after many attemps, so much i brought it back to depo and man in plumbing said many folks brought it back for same reason, they said they even had a hard time cutting it there... i just used copper and it was SO MUCH EASIER... just my 2 cents have fun.
Stuart in MN
Minneapolis
PVC works.
Driving without seat belts works too, up until the moment that it doesn't.
There are documented reasons why PVC pipe shouldn't be used for compressed air. People can choose to ignore them if they wish, but it doesn't change the laws of physics. Maybe those people should think about whether they want to endanger their friends or wives or children who may be in the shop, if and when the pipe decides to fail.
Abbott
U.S.A.
Yeah and you could die tomorrow Stuart. See that orange '53 Ford pickup in my icon, no seat belts is one of the perks. PVC works for air lines...if used the world will not stop turning.
BillK
Beautiful Southern Maryland
G
gmhill33
wantedabiggergarage
Member Emeritus
Independence, MO, USA.
toxicz28
NY
Don't do it!
The PVC police will come over, **** your dog, beat your wife and daughter, burn all your cookies and drink your beer. Then, eat your garage.
I'm warning you....
I fixed it for you! :thumbup:
Torque1st
MEMBER EMERITUS
KC Metro, Kansas
Gary-
Look up other threads here re that HF stuff, garage pak, etc. There have been problems with fittings, leaks, etc. Being plastic, it does not cool the air properly either. It is way to many $$$ for an inferior product. Of course if a person can't use pipe dope and screw pipes together or silver solder hard copper tubing it is an alternative.
Abbott, your definition of "works" must be off kilter somewhere. PVC is dangerous for compressed air. I have seen the results when it explodes. It is not pretty. Telling someone to use a product that is known to be dangerous by most people and even the manufacturers is just not cool. We have enough dangerous situations and materials in our shops, we don't need to be adding more. Especially since it may not be just the installer that is injured. We should avoid placing our wives, children, and friends in any more danger.
1320stang
Edmond, OK
Yes it can, and you can use a 50 caliber shell as a hammer too...
e-tek
Saskatoon, SK
Oh you.......(where's that "****-disturber" icon when I need it???) :lol_hitti
TAftw
Would the price difference between black pipe or copper and PVC really kill you? For that added safety, it's worth the money IMO.
SteveU
Thanks,
Gary
In addition to the safety factor the iron pipe will work much better for cooling and condensing the water vapor out of the air which will keep you from running water thru your air tools & ruining them.
G
gmhill33
Thats a plus. I didn't know that.
Thanks,
Gary
Kevin54
MEMBER EMERITUS
Urbana, Ohio
The injuries suffered to his right hand, middle, ring and pinkie fingers on his right hand are shown below to the right
Jeezus H. Christ, the write up makes it sound like a small injury. He blowed the meat right off of his hand.
And yes........that..... ladies and gentlemen, will make you scream in agony like a little schoolgirl along with filling your pants full.
regguy1
On Mount Olympus with Zeus
Charles
Charles, you're always a voice of reason in a sea opinions... well said.
Abbott
U.S.A.
Yawn.
IMO PVC works for air lines just fine for personal shops. I know several guys that have been using it for up to 20 years without a problem. All a guy needs to do is place it properly where there is little chance for it to get banged up.
Status
