Painting a Harbor Freight Box
devilphrog
Melbourne, Florida
So I have a bunch of the specialty tools that come in the blow molded cases that hold the tools and their accessories, and I need to come up with a storage solution that doesn't entail them being all over my garage and spread out throughout my box drawers (26" C-Man Ball Bearing), and I've been eying the HF Side Cabinet/ Side Locker, but the paint texture and color kind of drive me crazy, and I don't want to spend 450 bucks on a matching C-Man Locker. How well do you think it would turn out if I turned the side cabinet from red/pink to a platinum gray and black that matches the box. I don't plan on rattle canning it but maybe using a spray gun with my amateur painting/ prep skills. Thanks!
MechanicNamedJohn
This is the next project I want to tackle. Can't stand red or the wrinkle finish. I suspect we may be using Bondo as well. Even with that, I might use a semi gloss "or flat" black. I don't know how gloss black will look.
Jack Olsen
Los Angeles
I'm lazy. I used Rustoleum satin black on the drawer faces, and Rustoleum Regal Red gloss on the box. It's held up fine. The not-so-glossy finish the box comes with is good for taking paint. I scuffed, wiped with acetone, shot it with self-etching primer, and then Rustoleum rattle can.
I wanted it to match my Craftsman boxes:
D
devilphrog
Melbourne, Florida
Thanks for all of the responses and the pictures. As for the sandblasting, I believe that I will take the path of least resistance involving this project as I've been getting pretty busy at work and such.
Indy_500
Appleton, WI
Do not do this...
why not??? i didn't do it so i can't say to do or not to do really but i was just giving a suggestion and am curious why it would be a bad idea. wouldn't you want to remove the bumpy paint so you can down to the smooth metal?
mrholeshot
MEMBER EMERITUS
I had one of the HF side boxes (all drawers) and shot it with rustoleum satin black. The wrinkle black looks really good. I had it on my Snap-On 1023 roll cab. I got it for 50 dollars so I used it. The wrinkle black looks killer
mojo_13
Iowa
Did mine the same way that Jack did only on a tool cart. And it came out pretty well for a first timer. I would have no problem doing it this way again, but you could spray it if you had the equipment.
Edit: I only painted the drawers black, I did not repaint the cart red. But might buy another one and try to repaint the whole thing before I assemble.
NUTTSGT
Northern Central Ohio
I'd think the wrinkle finish is what will give you the most fits. First you need to scuff the surface before you paint it for good adhesion. Then you have to wipe all the **** you just scuffed off from the wrinkle finish.
I think I would try painting the back first (if it has the same finish) to make sure everything is ok.
Tink
Old Bridge,N.J.
The black wrinke finish looks good on a box. I have a Penny's box from the late 70's with this finish. With the satin finish on the HF box I would probably just clean it and use a rattle can. The self etching primer wouldn't hurt.
68rustang
Cleveland, OH USA
Did you guys remove the HF texture paint before spraying? it doesn't sound like it but I am not sure of the point of etching primer unless it was bare metal. I am probably going to pick up a few of these this week for a workbench and will probably be repainting them.
csp
Franktown, CO
I sanded the texture off of mine with a DA, but didn't completely take it to bare metal. Wiped it down with mineral spirits and shot it a navy blue.
There's no need for taking it to bare metal to get it smooth.
bullfrog123
SE Idaho
Repainted mine with Rustoleum rattle bombs and it turned out great. Scuffed the whole thing, wiped it down with acetone, spray away. It is still a little "textured" but not that big of a deal. Matches my C-man boxes pretty close.
myboostedgst
Milwaukee
Can you post a picture? I am planning on picking up the HF box and painting the drawers black, but still hate the wrinkle finish. I would have no problem sanding it completely down and painting everything.
But I really do love blue boxes!
Sterff
PA
I did mine about a year ago...
pcpro15
Awesome Job Guys! Might have to do that to my HF toolbox someday :D
Jack Olsen
Los Angeles
It was the primer I had on hand. You're right in that it offers no advantage when it's used over paint (as opposed to on bare metal).
I scuffed the surface, but did not take it down to bare metal at all. The 'krinkle' surface might vary from unit to unit. Mine is/was pretty smooth.
68rustang
Cleveland, OH USA
Thanks for the responses. I picked up two of the 13-drawer lowers and one of the 7-drawer side boxes Saturday. I actually don't mind the finish as it is afterall. It is nice that the side box is hooked and bolted to both lowers. I can't steer it around anymore but the wheels will be removed and a benchtop added soon anyway. Once I get done figuring out where everything is going to go I will probably go with the standard Craftsman black on red theme.
IBJanky
Long Beach, CA
I am thinking of buying this tool cabinet and doing the same thing.
After I scuff the red crinkle surface, do I have to spray some primer first, or can I just shoot the black Rustoleum on the drawer faces?
myke
bullfrog123
SE Idaho
myke
I didn't do primer because I didn't take it down to bare metal. The black I used is an ag paint which takes a day or more to dry but sticks like no other. The red is just safety red Rustoleum.
88thunder
Perfect opportunity to shamelessly show off my toolbox i finished yesterday. Its a craftsman 3 drawer portable tool box from Costco. Came red with black drawers but since i'm not a fan of red boxes something had to be done. Removed drawers, DA'd large areas with 320 and scuffed the rest with red scotch brite. Paint is actually automotive urethane primer i tinted with universal tints to the color you see. Followed the first two coats with two "sealer" coats (reduced the same primer, added flattening agent, sprayed thinner. All exterior painting was done after the bottom and inside. Though it is "just" primer, when you leave urethane primer alone it has a very sealed surface...ie won't show oily prints (at least with this brand primer).
As a couple have asked... no need to prime over your "scuffed" painted surface. As long as the finish has the appropriate "tooth" it'll act as your primer. Though it can be done with a spray bomb, spraying with a gun will achieve much more uniform results.
marcusicp
NC
Looks great! Did you just tape off the latches?
PSYKO_Inc
Fairfield, CA
Just wondering if anyone has tried to chem-strip the wrinkle pink finish on the HF boxes. Should go a lot quicker than sanding and no chance of warping the sheetmetal like bead blasting, just wipe it down with lacquer thinner afterwards and roll straight into etch primer.
mikeceli
I WISH I had enough spare time, to ponder a color change, on my tool boxes!
