Mini Review: Bahco Big Mouth 8231 Pliers
Bolster
Mexifornia
Found these 8" Bahco Big Mouth Ergo Adjustable Joint Pliers (8231) on Amazon for $14.
They look to be similar to the 7" sold by Snap-on for $46 or the 10" sold for $52. Their claim to fame is that they "...feature 12" capacity in an 8" pliers!" Max open jaw size listed 1.5" which seemed OK, but it looked bigger in the photo. I was curious, because I've been looking for big capacity in the smallest possible pliers for my "traveling" box that is always over capacity. Seems emergency plumbing always calls for really large pliers.
The 8231s arrived the other day, and they actually measure 8-3/4 from tip to tip (should be called 9" pliers). Made in France. Ooo la la. A little quirky, like you'd expect from the French, but I'm keeping them. Positives outweigh negatives IMHO.
Negatives
- Jaws move just 3/4" of an inch from open to closed. The workaround, obviously, is to adjust the pliers to fit the project. But that's not a lot of jaw swing between open and closed.
- Lower jaw moves side-to-side about 1/16 inch in either direction from the top jaw. It's a function of the design, so you can't expect the top and bottom jaws to close in perfect alignment each time.
Positives:
- Really do have a capacious opening size for 9". Max open size is 2.5", but is unusable at that opening. The bottom three ratchets are not functional at all (so why are they there?). When you squeeze the handles at max open, you'll get three ratchet clicks to the first useable notch. At that location, max open is 2.25", much more than the advertised 1.5" (it is 1.5" closed at max opening). That's pretty serious capacity, so despite the redundant ratchet settings, I list this as a big positive. That's a lot of opening on any plier, let alone a 9" plier.
(Interesting, it looks like you could tease a little more opening capacity out of these if you'd file or grind a protruding flange on the foremost grip, where the soft grips end and transition to the metal.)
- The thumb button adjuster looks plastic in all the photos but it's not, hurray. Press it to adjust, simple. If you open wide, you can ratchet it closed to the adjustment you want without pressing the thumb button. But to open wider you must press.
- LOVE the depth of those jaws! From throat to tip of the jaw is a whopping 2". These are some serious deep-throat pliers.
- Look and feel of the jaw teeth remind me very much of Knipex cobras. Sharp teeth. Only time will tell how hard the jaws are.
- As comfortable as they look.
I rate these TWO ROASTED GOPHERS UP because of their large capacity (opening AND depth) in a compact tool, their European design and manufacturing (which I hope means well-hardened jaws), and their bargain price. Try a pair and tell me if you agree.
Some photos with competitors:
fourfeathers
QUAD CITIES, IL
I have a pair of Bahco Sandvik pliers w/ same design, but full size, and they have held up. I think they rust a little too easily. Mine are 8225 model #. France, eh. I thought it was Sweden or ???
Bolster
Mexifornia
i can tell you after using the knipex wrench plirs i have no plans to replace the pair that went missing wrench pliers, do it
Knipex's wrench pliers are great (I own 3 pair) but I would not use them for the same jobs as these. The Bahco Big Mouth are sort of a compact and inexpensive Cobra IMO.
X1 Mike
Flagler, Fl
Bolster,
I found this review thanks to the link in another post. I may be swayed to check them out because of your review. Thanks for taking time to show us what you found.
:thumbup: :thumbup: (I'll pass on the roasted gophers, thanks) :lol_hitti
lipadj46
I have those bahcos along with the larger 16" model. The 16" pair has a metal adjustment button which I like better than the plastic one on the smaller model. I like them but I don't use them very often. I have not used the knipex yet so I guess I don't know any better.
zer0cell
Does anyone here have an opinion on the Crescent Pliers pictured above? The set for both of them together was $15 at home depot which seemed pretty affordable for even those with a modest budget. At least on the packaging they say USA which is nice too I suppose. Anyone?
egdede
The newer 10 & 12 Cobras open larger. They would appear to be similar to the Bahco's.
Bolster
Mexifornia
As I mentioned in the review, the button on these 9" Bahcos is metal not plastic.
You'd expect the 12" Cobras to open wider (see the comparison photo above with the red-handled 12" Cobras). But compare apples to apples, and the 9" Bahcos open 1/2" wider than 10" Cobras.
And the Bahco jaws are considerably deeper. Throat on 10" Cobra is 1-1/4, whereas Bahco is 2-1/16.
lipadj46
I have them and every time I try to use them they just don't quite work out. I have the 18" bahco and like it much better. I think the proportions are just off on the 8"
Theloniousmonk
Where the tall corn grows!
I was going to go on a 5000word tangent about these, but everything has pretty much been covered in much less space, and more eloquently than I could offer.
I would like to add that I hate the release mechanism, it doesn't feel "right", you push to release and nothing happens, you push again and it moves only so far before catching, I have to apply rather forceful pressure to adjust the pliers properly, just not very intuitive. I bought a pair a while back thinking they would be the "end all-be all", but rarely if ever use them today. I like the nothrills of my Facoms and the Knipex Allys... these Bahcos have become eye candy in my box.
Also, I would ask Bahco: "What the hell is the point of having such a large jaw opening if you can't apply pressure to the jaws due to interference on the handle at the bottom 1/4 of the neck?"
Monte's pic of the jaw "offset" is hilarious, belongs on failblog or something.
Monte
Germany
I kind of liked them right up until Monte made those last two post,lol
ooops sorry :D.
Maybe it´s just my and Bolsters pair, could be a not properly straightened blank after forging so this pic need not to be a representation of ALL of their pliers.
Maybe you like them again when you look at this pic :D
(model # 8223 + 8224 though)
Bahco 8224 compared to old Knipex Cobra
Bahco 8224 compared to NWS QuattroGripp
Bolster
Mexifornia
Oh good, finally, some reactions to this old post! Looks like everyone's lining up for a bashing...which is fine, as we've all noted, they're not the quality of the more expensive Knipex. Some responses to posts:
I thought I was pretty clear about the jaws having lateral movement, but maybe you guys need pictures not words. The jaws don't just line up on one side (ie, they're not "off" on one side due to shoddy workmanship); they move laterally because of their chosen hinge mechanism, which allows lateral movement to both sides. To get Monte's photo you'd have to push the jaw to that alignment, but it CAN be done and you CAN take a photo like that. [EDIT, actually I can't. I can't get my jaws to go that far off center. see photos below.] That's not how it normally closes, however. That's a "drama shot." Or it would be on mine, maybe Monte's actually close that way every time? If so, that would be a problem.
Regarding the handles coming together...I simply missed that, did not notice it until Monte posted. Grabbed mine and it's the same. Good point.
What we are seeing here are the tradeoffs for the large jaw size in the compact space, using this particular hinge mechanism.
The proportioning on those pliers look weird. I don't think I would like them. :headscrat
No disputing of taste. The proportions are what I like about the pliers. Not the looks, I could care less about the looks, but I like the small-handle-superlarge-jaw. Mine are in my portable box where I want maximum jaw size in minimum overall length. (Mine are for plumbing applications mostly.) That means proportions that are odd.
I've been wanting to read this post since Thelon mentioned he didn't like the pliers in another thread. Thanks for posting!
I totally agree with the question about the overly large ratcheting section, the lower portion of which can't even be used...that confuses me (as I stated in my review).
As far as the mechanism "not feeling right," ... well, OK. Yeah, I'll agree the button doesn't have the positive feedback of the much more expensive Knipex, but I haven't had the trouble changing the adjustment that Thelon mentions.
For me, the thumb location is more intuitive than having to flip the pliers on their side and press a button on the side, as the Knipex. But the adjustment is not as fine as the Knipex, so there is not the satisfying feel of a fine ratchet as you adjust. It's a coarse ratchet.
It's a Kalashnikov, not a Colt.
Thanks for the replies! I was beginning to think I was the only guy who owned a pair.
My impression after having owned them for awhile is that they're a 'niche' plier. They work well for my particular application, which is big-jaw compact pliers for the traveling box; but they have not replaced my Knipex for bench work.
Theloniousmonk
If I used them everyday, and practiced the motions of release-ratchet-grip for a while, I can see how these w/b useful... but I dont. I'd grab my old channellocks before these.
Some positives though:
The grips are nice and seem to be of good quality composite - I haven't melted them.
The teeth are also stronger than some of the others I own... My facoms have a few garfled teeth from medium duty clip & fitting removal, the Bahcos had seen similar duty from time-to-time and have no marring or garfling of the teeth.
Overall, these ARE functional pliers, and i'm picking at knats when complaining about them.
Thank you Bolster for the thread and opportunity to add my experiences.
cheap bastard
I've had a set for about a year. They cost about $15 as the store got them as part of some one time deal. So far, they have been a good plier. I grab my Channelocks or old Macs more often, so I guess they're preferred. The finish has held up very well and the grip is very good with less force due to the sharp teeth. They do leave "prints" on most surfaces and require a bit of care. They are going to go in the truck box, soon I'd say.
Bolster
Mexifornia
I don't own any stock in Bahco, so I don't get a penny richer whether you like these or not. BUT, I do think they deserve a fair evaluation. The criticisms about pinch handles and jaw closing got me to wondering: "Compared to what?" The ideal Platonic pair of pliers?
First, "Proportions." I've never bought pliers based on my idea of ideal proportions. But I do see what you mean. They're sort of Dolly Parton pliers. Mouth, ***** too big. Body too short. Can still sing though.
Second, about those "pinchy handles"...unique to Bahco? Hardly:
At least the Bahco don't WANT to stay closed like that, they try to spring away from the pinch position (thus the rubber band for the photo).
Third, what about those misaligned jaws, which I mentioned in my original review. Are those unique? Again, hardly. All comparisons here are "drama" shots where I pushed the jaws to the side for the photo. In order they are Bahco, Proto, and Knipex:
I'm not thrilled with ANY jaw misalignment, but the Bahco are certainly not out of the range of normal.
Again, I'm not selling these, so if you don't like them, fine with me. Heck, they're French pliers, and I am not a good example of your brie-eating, snail-sucking, government-owes-me-another-day-off-work socialist Francophile. But I think the criticism of these $14 pliers should at least be placed in context with competing products, and not the object of unfair comparisons against Plato's ideal pair of pliers.
mrholeshot
MEMBER EMERITUS
Bolster, wasn't trying to offend your pliers but thatks for clearing up with the comparison. I like the really deep jaws of those pliers
Bolster
Mexifornia
Guys, I don't have an ego-investment in the Bahcos, so your negative reviews are perfectly welcome here. If I thought the Bahcos were 'all that' I'd have sold all my Knipex and replaced them...which I have not done, and don't plan to. The Knipex are IMO superior. But I may have questions abt the Bahco criticisms if they don't match my own data.
I saw that zigzag on Monte's and I'm at a loss. Do other Bahco owners have the Zag? Why would they machine/grind in a zigzag?? Two matching zigs, how could that be an error? I don't see either the zigzag or that extremity of offset on mine...but...there's certainly some variation at that French factory. Perhaps Pierre had a little too much wine before making Monte's? Perhaps Pierre knew they were being sold to a German and sabotaged them? Because the French love us Amurikans now that we shot ourselves in the foot in 2008.
Monte
Germany
not to beat a now dead horse, but the machining on the jaw mouth looks zigzagged - looks to be more than just play in the jaws.
maybe this is why the plier always look like that when i close them........... (no pushing sideways) The other pair is not as bad !
The NWS pliers have a side play of maybe 0.2mm or 0.3mm or so (pushed sideways) During normal closing they always align.
Here some shots from the pictured Knipex: (without pushing sideways, just normal closing)
first attempt to close it
2nd
Monte
Germany
sorry for the OT again :D
Orbis makes similar pliers like the Bahco + NWS pliers with automatic adjustment:
"Orbis Speedy"
Will also makes similar pliers:
"Will Gripstar" ("Atorn" branded)
No push button etc. at all, just open the handles and slide the handle back to open the pliers.
Bolster
Mexifornia
So those most recent misaligned-jaw photos are of Knipex not Bahco, yes?
OK, I repeated Monte's test with my Bahcos. I closed my pliers 5 times (no pushing on the jaws, just random closing) and this is what I got:
You can see there is some movement of the lower jaw laterally. Seems within normal range to me.
And on a more intriguing note, have any $14 pair of pliers ever been subjected to this sort of international scrutiny before?
@ Monte: If your Bahcos are well worn, please tell me how the teeth are holding up. Well hardened or not?
Theloniousmonk
Mine are not that far off (compared to Monte's), nor do they have the zigzag thing going on... they do not line up when fully closed, but if you ratchet down a couple clicks, it evens out. I did notice that the little free cogs in the ratchet mechanism are a bit uneven and don't line up w/ eachother, could be why mine seem to take a bit of force to open all the way, could also (besides the needed play to not bind) be the reason why the jaws don't line up completely when closed. Machining wise, when you line up the jaws, they seem to be square. I see the ratchet mechanism parts and the fact that play is needed between the two main pieces as the alignment issue.
ratcheting "cogs" do not align are pretty uneven in their casting/stamping... i bet if someone popped the role pin, that hold them in, dropped the cogs, cleaned them up w/ a file, the movement would be much smoother.
I doubt anything that costs $15 has ever been subjected to this much scrutiny... anything
blue dog
Culver City Ca.
BOLSTER, in one of your posts above, you have a pic of a red handled plier that has the name MILBAR on the handle, what are those used for? and, what material are the white pads inside the jaws made of?
Bolster
Mexifornia
They were sold to me as pliers for disassembling lenses. I used them for that, and any round objects I don't want to scratch. You know I have no idea what the actual pads are made of, but they feel like common hard plastic.
jsackin
Kansas City Missouri
I've always heard of them referred to as "Cannon Plug Pliers".
comedyman809
Smithtown, NY-thats in suffolk county long island.
cannon plugs would make sense.
some cannon plugs can be very stubborn, but also need to be treated with little stress as the plug has sensitive pins inside both the male and female ends.
so the soft grip pliers to remove the male end looks like a very useful tool.
ive seen a lot of cannon plugs on helicopters when i was in the air wing of the marines.
im sure lots of aircraft use them, and im sure there is more on other things.
aircraft is where i remember seeing them the most.
i remember saftey wiring every cannon plug on the cobras and hueys.
