OK, that's it. I'm giving all of you the "Finger"
OccupantRJ
Eastern North Carolina
This is my tool creation that I named the "Finger" It is extremely handy for holding those hard to hold teetering metal pieces while tack welding. I built this over 30 years ago, so you know I hang onto my tools. It had rusted from the flood, so I blasted it and put a coat of cast iron color paint on it. The finger is adjustable in reach and rotation for those hard to hold applications. It is built of solid 1" X 1-1/2" hot rolled bar stock, and the weight is cantilevered into the finger tip to apply a surprising amount of pressure to hold parts steady.
The legs are 16" long, the finger is 20" long and 3/8" diameter, and the legs are spread 13" at the base. Weight is about 14 lbs. The wing bolt for adjustments is made from a buttonhead allen bolt with a side plate from a roller chain welded on for a finger grip. This thing is rather handy on a welding table, so make yourself one and enjoy.
RJ
t100
I have one similar, used it for couple years, very effective. there's one at the shop made by Lincoln probably 30 years old.
Stick
Alaska
At my work, we call them dumb birds, because they just stand around and hold stuff. I've got a few of these in assorted sizes in my toolbox for work. I usually end up welding bits and pieces onto them to give them a little personality, locknuts for eyes, ading wings, etc. My favorite one has a weight that slides up the main shaft to give it adjustable holding pressure, and the base swivels so it can lay flat in a toolbox drawer.
O
OccupantRJ
My version will also swivel to lay flat if one desires, and it ends up being 1-3/4 inch high. I usually keep mine right on my welding table at home, because it's so handy.
Nightshift
London, Ontario
That's a great tool. Been meaning to make something like this for a while now. I like your design ... it will be duplicated in my shop! Cheers, Bill
RetroJim55
Abbottstown , Pa.
Now that is a great idea . I have used many things so far but your design is the best I have seen . With the adjuster so you can slide the rod in and out and at any angel really makes it a winner !
Thanks for giving me the ""Finger" !
Jim
O
OccupantRJ
It's doing it's job in the pics. If you note, on the table is a small piece of flat plate, with a short piece of keystock standing up on it. The downward pressure of the finger allows one to tack weld, braze, or solder the 2 pieces together while juggling all the things required to do so. Without something to hold things in place and aligned, it's a wigglefest, and will make you cuss.
steel 35
Between the PNW and the Emerald Triangle
I had way to many projects when I found this site and with things like this sticking in my little mind I am overwhelmed :headscrat with the addition of trying to clean my shop after being disgraced by looking at a few, every time I clean a spot I find room for something else..........One of three jobs I got done today, and I had to work. Thanks for sharing. :thumbup:
O
OccupantRJ
Steel, that looks great! Both classy and functional! Good work! OK, any others made one yet? If so, show it off!
