aqr81
I have recently been wading my way through deciding upon a lighting plan and want to share a few things. First, start by doing your research here and on the web.
Next, go to Lithonia’s site – you can get to their resources HERE. Download and install “Vision” which will help you with all the calculations and layout for your project. If you don’t set up an account for software usage, it will expire at the 30 day mark. All the tools are there for you for free. You can download the photometric file from the mfg and select the light fixtures you are considering for use.
You will need to enter all the pertinent parameters; length, width, height, reflectance, work plane height, mounting height, select the lighting fixture etc. It will even let you change layout by rotating the fixture 90 degrees. You select the variable: fc, lux etc. The software does all the calculations and shows you the results of average illumination, layout with the specs for spacing.
When you are doing comparisons of various lighting options make sure to have the parameters set correctly and consistently:
Larry
- Make sure your working plane is set at the correct height
- Set the fixtures at the same elevation (check the software and try different heights and see impact of these changes)
- Consider low bay lights and direct lighting over work benches
- There are many references on the web for various lighting requirements depending on the type of work being performed. More is better and can be controlled with multiple switched circuits.
- Don’t forget to search here and do a lot of reading of available information on lighting layout…
Larry
