dcovey
I have been waiting until I had a decent start before starting a build thread.
I want to thank 53 Driver for the recommendation of Rob Bilt out of Oklahoma.
A little background. I spent at least the last six months researching and getting bids for the building. I wanted a metal building and was leaning heavily towards wood/metal, I may be wrong but I just feel they are as strong as an all steel building and I also think they are easier to finish out on the inside.
I received quotes from about 8 different places ranging from 50,000.00 plus install to the low of 15,000 installed. The all metal ones were out of my price range at 30 to 50k plus labor.
So since I was already leaning towards a wood/metal that is the direction I took. I had several bids and had each send me a blueprint or at least detail how it was built. Believe it or not but the least expensive was actually the better built building. As an example the posts are on 10 foot centers with a double 2x6 top plate, other did not double up. 2x4 purlins and girts on 24" center nearest had them at 26". Plus there were a couple of other things done that I liked.
I went with the Rob Bilt at $14,300.00 installed.
So far with 5 working days that include site prep here is where it's at.
I had them come in and get what you see of the building up and stop at that point. Without the trusses and doors framed out that allowed me get a concrete truck all the way in the building. It saved me from having a concrete pump ($900.00) or from having to pay extra for manpower to wheel barrow the concrete. I payed $.50 a foot labor for the pour and finish ($1,200.00 labor + $120.00plastic, + $150.00 to saw expansion joints).
I talked with four concrete companies and several contractors and all agreed that I would not need any steel if I used fiberfill in the concrete. My last shop (30X50) was poured the same way and after 15 years it had one crack where we figured to have a problem. So I am confident it will be good. Even if someplace down the road I do have a problem I can always cut it out and repour.
The crew are supposed to be back Monday 20 Sep to finish the building.
Here are some pictures of what has happened so far.
