How many ratchets do you own?
ImportTuner
After my last purchase of the Proto ratchet, I decided to count how many I own ... OMG, I have 34 ratchets ... :)
Deafautotech
Indianapolis, Indiana
i have four 1/4dr ratchet, one 1/4dr breaker bar, four 3/8dr ratchets, one 3/8dr breaker bar, 5 1/2dr ratchets, one 1/2dr breaker bar, one 3/4dr ratchet and one 3/4dr breaker bar.
kythri
Lebanon, OR
3 1/4" drive ratchets
1 1/4" drive breaker
3 3/8" drive ratchets
1 3/8" drive flex-head ratchet
1 3/8" drive breaker
3 1/2" drive ratchets
0 1/2" drive breaker :(
jerryW
Phx AZ
HAH!!
I just counted 40! Not including ratcheting adapters or torque wrench ratchets, breaker bars, t-bars etc.
jerry
Jokeman
Boston
I knew a few but after seeing this thread I counted 38. Im sure there are a few more in other toolboxes too.:shocking:
SuperKid
Indiana
My collection is pretty small:
3 - 1/4" Ratchets
1 - 1/4" Breaker Bar
3 - 3/8" Ratchets
2 - 3/8" Breaker Bars
3 - 1/2" Ratchets
2 - 1/2" Breaker Bars
1 - 3/4" Ratchet
1 - 3/4" Breaker Bar
I
ImportTuner
Now, I don't feel so bad .... jokeman has more than me ... :)
:bounce:
Junkman
Northeastern CT
After a certain point, it is an obsession, not a need... Have any of you considered seeking help from Ratchets Anonymous, or some other such help group? I can see the adds on TV now...... Are you married to a Ratchet Collector that needs help??? This is almost as bad as the guy that collects oil filters for a hobby... :headscrat
Deafautotech
i work where i change lot of mopar oil filters in chrysler dealership. i dont do oil and filter change guy. i am more like entry tech and heavy line tech(when need to pull transmission or engine out)
eschoendorff
Okay... here we go:
I have:
4 1/2 drive
17 3/8 drive
5 1/4 drive for a total of 26...
and then 3 1/4 breaker bars, 3 1/2 breaker bars and 2 3/8 breaker bards that I can find.
There. That's all I can think of. And I have NO IDEA why I honestly own all this junk. :bounce:
The sad reality is that I have all these ratchets, but I am probably the weakest mechanic on this board. :lol:
Rickster
SE PA
The 6 1/2 in ratchets or even the 24 3/8 drive ratchets weren't alarming, but the 17 1/4 inch drive ratchets were a surprise. That's 47 total and one on the way from ebay!
wilbilt
NorCal
This is just a sickness, you know? Just like alcoholism and off-topic posting.
There is help available.
Hi. My name is Will, and I'm an off-topic poster.
See? It's easy once you admit you have a problem!
:lol_hitti
eschoendorff
:lol_hitti
I just don't see the problem (denial).....
toms73novass
grand island, ny
Ok, you guys probably won't believe this but I have only
1 1/4" craftsman ratchet (it *****!!!) need to get a better one
3 3/8" craftsman (it's ok)
snapon (very course mechanism)
Proto (so far it's my favorite)
4 1/2" craftsman (it's ok)
snapon reg length (ok)
snapon angle head (don't really use have never found it comfortable to wrench with)
snapon adapter ratchet for my snapon breaker bar (this little adapter is one of my favorites!!!)
dink
Plainfield, IN
You must be just a weekend ratchet person.....(think weekend drinker euphanizism)
Be a true ratchetholoic :beer:
toms73novass
grand island, ny
I was fighting with the computer on my last response!!!! the whole thing didn't work , fixed it.
My snapon's are probably 60's vintage.
Have they refined the mechanisms in them since then?
That 3/8 is very course click, click click and you are 1/2 turn around....
toolfreak
Illinois
Tom try taking your ratchet apart and putting some good grease in it. I did this with a 3/8s sealed head ratchet and it is probably the smoothest ratchet i have.
jerryW
Phx AZ
The absolute smoothest ratchets I own are the Plomb and Proto's. Every time I see one at a swap I will buy it if it's reasonably priced, under about $5.
They are my most used and the ones I'll grab before my Snap-ons or Craftsmans.
jerry
toms73novass
grand island, ny
Took it apart and cleaned and greased, only minorly better.
Jared
Victoria B.C
2-1/4
5-3/8
3 1/2 and a breaker bar for 1/4, 3/8 and 1/2
Wow i really need more ratchets now, i will have to start goin to the pawn shop again.
Jared
TNToy
West Tennessee
Yes.
Yours (you can tell from the round snap-on logo on the back of the head) are an older design. Current snap on ratchets are fairly coarse by most standards. 30 teeth. (12 degrees movement for each tooth). The heads are also thicker. They do this for durability: The more teeth you add, the smaller each tooth is, and just one busted tooth means it's time for a rebuild kit.
Yours is coarser. Before they started with the current sealed-head design they had 26 teeth. Yours, being older, might have even fewer teeth than that. I don't know. I've got a 1/2" drive version of that same ratchet from the 60s or 70s, and it's very coarse.
My favorite ratchets are Matcos AFR, BFR, and CFR 60-tooth ratchets. Very thin sealed head with 60-teeth. Very smooth. :)
TNToy
West Tennessee
...And those of us who do this for a living have somewhat of an excuse:
1. Duplicates are a backup in case one breaks, to get us by until the tool truck can come warranty it.
2. I may use 6 ratchets at any given time. If you know the order you need to remove everything, and what size all the fasteners are... you can lay out all your tools in order of use and fly through the job.
Changing sparkplugs on one vehicle I regularly service:
I stick a T30 torx socket on my 1/4" air ratchet...
A 10mm socket on a 1/4 or 3/8 flex-head ratchet...
A sparkplug socket & 6" extension on a 3/8" ratchet...
Another sparkplug socket & 6" extension on a 3/8-drive torque wrench...
And I'm done pretty quick. It's quicker to grab another ratchet with the socket you need already on it, than swap things around, drop them, and have an extension or socket roll under the heaviest thing in the shop. :)
I
ImportTuner
TNToy said:
Yes.
TNToy ... you need to try out the Snap On F872, round head ratchet. It has 72-teeth and 5 degreee movement; it's one of the ratchets in my collection ..
:bounce:
TNToy
West Tennessee
I don't like round-heads in general. From SK, Snap-On, or anyone else. The head's too bulky. If I want a lot of teeth for a really tight spot, I grab a Matco 60-toother. :)
kartracer55
Multiple ratchets are nice for exactly what TNT said. Sometimes you need a fine tooth ratchet, other times you need a long handle. It goes along with ahving the right tool for the job. It can make life WAY easier
Jim
mulepackin
Montana
At home I've got 6 ratchets, 4 breakers. On the ranch we must have about 50 of various sizes (breakers included).
kartracer55
1/4: 4 ratchets, 1 breaker bar and one air ratchet
3/8: 8 ratchets, 1 breaker bar, 1 palm ratchet, 1 speeder, and 1 air ratchet (and an impact)
1/2: 2 breaker bars, 2 ratchets and an impact
Ive got one cheap oil change ratchet in the garage too
EDIT: and a slide handle in 1/2
Southern Europe
1/4"
2 fixed head
1 breaker bar
3/8"
2 Standard length fixed head
1 long handle fixed head
1 long handle swivel head
1 speed handle
1 T bar
1 air ratchet
1/2"
1 standard length handle fixed head
1 speed handle
1 breaker bar
1 air ratchet
They are a mix of Snap On, Grey and Beta
boiler7904
NW IN
After reading through this thread, I have an woefully inadequate rachet collection:(. It definitely needs to be added to.
wantedabiggergarage
Member Emeritus
Independence, MO, USA.
Right now my shop is torn apart, as I am trying to reorganize, and build some new benchs/cabinets and such. So I refuse to go digging to look (denile, don't want to know how big of a problem I have). Had some tools stolen a while back that I haven't replaced (not in the budget at the time), but I know of a way to help you all with your tool adictions. Send them to me:thumbup:
:lol_hitti
eschoendorff
****. I forgot about palm ratchets, air tools, speeders, sliding t-bars, etc. Screw it. I'm NOT going back out to count. :bounce:
