$15.00 Drill Press (I'm 54, and she's older (PICS))
hofferwood
DownRiver Michigan
Do ya think She'll clean up?
She's old
I think it will (more to come)
Chuck
RM209
MD
Excellent job! I like the hammertone paint.
RM209
north
Norway
Beautiful drill press and very nice job cleaning her up and with the speed reducer. And all done within 20 minutes. Gotta be a world record. :lol_hitti
Packard V8
Spokane, WA
Is the head casting aluminum or cast iron? Many Shopmaster tools have lots of cast aluminum parts.
jack vines
woody 73
The Great State Up North
The belts remind me of Link belts that I see in my woodworking catalogs,you just add or take out a link when needed.
Very nice drill press restoration,the very first picture reminded me of the cone heads on sat. night tv.
ironheadtom
Kentucky
That thing looks great. I'm going tomorrow to pick up some similar paint for mine if I can find some.
H
hofferwood
DownRiver Michigan
First, I'd like to say thanks for all the responses:thumbup:
It was a G-sale find, last one on the way home, go figger.
nice job! how did you manage it...what method did you use for the rust/paint removal?
Hey mkdive, the paint was easy, medium stiffness HAND wire brush. the surface rust on the main post, I chucked it up in my mini lathe(7x10), used the speed reducer as a steady rest, scotchbrite and it cleaned right up.
Looks nice, well done. What kind of belts are those?
Well Dmessin, the belts are accu-link, I looked all over for them. Amazon wants close to $9.00ft, found it at HF(on frickin sale now)http://www.harborfreight.com/vibration-free-link-belt-43771.html
Why not stick with the original green? that would have looked sweet. Not that it looks bad:thumbup:
I looked for the Hammered green, but I couldn't find it handy. And I think it may be ironheadtom that said, kinda tired of green machines,me too, ie-id grinders,3and4 head vertical lathes,compacting presses(440 ton cinci's)
jack vines
Yes, the head is cast aluminum, one piece, hollow and very intricate inside. It would be interesting to see how the inner mold was made. It is completely BUSHED (brass/bronze), with absolutely NO wear. I am amazed. The only bearing is the roller thrust(between the quill and shaft),cleaned and repacked. The base and table are C.Iron.
I want speed reducers like that on my drill presses. how did you fabricate yours? sombody posted one before.
Yes, it was "keep" the last post herehttp://www.garagejournal.com/forum/showthread.php?t=53716&highlight=drill+press+mods&page=2 Stole the ide'r from him Thanks keep. If any interest I'll post pics of it on this thread.
The color believe it or not is "dark bronze" Rustolium hammer, got it at wal-mart.
Really nice work on that one, a few more DP's over here:
http://www.owwm.com/mfgindex/detail.aspx?id=746&tab=4&sort=1&th=false&fl=
A DP like that is pretty useless without that speed reducer, you get a gold star on that one too!
Thanks lilredex, I found "OWWM" when I first got the old girl, If you check out the publications on that page, they have the shopmaster catalogs also. These dps were sold without a motor, so the one on her may be orig. to the press????
The chuck seems ok for now, thanks again
The link belts will run more smoothly than the V belts. Especially if it doesn't get used often.
Absotivley, and with our winters up here, v-belts take a "set"
Thanks again all, now watch me take some heat:pimpflash
$16.00 HF closeout with cooopun
Chuck
H
hofferwood
DownRiver Michigan
and worth exactly what you paid for it.
I agree! IF, you intend to use it as a "Cross slide vise to mill"!!! As I stated above there are no bearings in the dp for lateral stresses. My use for the x-y axis is to center stuff a little more easily (blind old arthritic pos that I am):lol_hitti
So for this application it works quite well.
Thanks
Chuck
H
hofferwood
DownRiver Michigan
Sorry it took so long, but here's the speed reducer.
The main center section is a hunk of 2 1/2" aluminum round stock
I turned the minor diameter to 1 1/2". Then drilled the thru hole, cut the bearing recesses (bearings are from an alternator I had).
The shaft is 5/8" steel.
As far as dimensions and plans or drawings, I just did it all on the fly
Thanks gang
Chuck
Brad54
why didn't you use time period correct V belts?
He touched on this, but I'll elaborate a little: V-belts take a set around the pulleys.. and not only will they be oblong, but they'll be egg-shaped as pulleys are usually one big/one small.
When you run the machine, that oblong belt running round the pulleys creates machine wobble, oscillation and vibration.
I've got a pretty nice Shop Fox horizontal band saw, with a small V-belt drive, and that thing bounces around so much that I have to let it run for 5 minutes to soften up the belt before starting a cut, otherwise the whole head of the saw bounces around.
That's just the kind of thing you don't want a drill press doing while boring a hole.
I simply haven't gotten around to ordering a link belt for it, but it's coming. In fact, I'm going to check that link right now.
-Brad
vectorges
I have the same drill press. It was my grandfather's, and he dies in 1972. I still use it. Recently the nuts on the little spring assembly on the left side opposite the "push down" handles loosened. Do you know the proper way to set the tension on the spring and tighten it? The spring has a hook on one end that engages notches in the case under the stamped steel cap.
BigDaddyUSMC
Santee Calif
Well it is now 6-19 2020 , I just paid $40 for this exact same DP today at an estate sale. Sadly the top belt guard is missing so the search is on,,, besides being ugly mine is in great shape mechanically , needs to be rewired , cleaned up & painted.
dwcon1431
I have one that's very similar, if not identical. I got it for free from my nextdoor neighbor. I already have a bench model so, with this one, I bought a solid aluminum pole and made a box with wheels to turn it into a floor model. It sounds like I feel (at 67) but, it works just fine.
Sent from my SM-T580 using Tapatalk
