leftyz
I have a project in which a 3" long x .5" OD piece of steel tubing, protruding from some light steel, needs a tight, secure connection to a piece of 4.5" long 3/4" OD .510 ID steel tubing.
(ascii art not to scale
the dashes represent the inner tubing with OD of 0.500"
the equals sign represent the outer tube with the ID of 0.510"
So there is 0.010 gap total between them.
I can try to weld the larger tubing to the base, but I'm worried about blowing through the thinner steel without getting a good weld to the 1/8" (actually its .120") walled larger tube.
a few other ideas:
Any other ideas or preferred methods for this?
I was originally going to have a machine shop turn out a .499 ID in some 3/4" OD round stock I had bought, but they wanted over $100 for this, so I went and bought DOM steel tubing for $11 and I'll make it work.
Thanks!
a few other ideas:
- Drill a small hole through both outer and inner tubes and use a roll pin to secure them
- weld some material to the inner tubing, then grind it down until hammering on the outer tube makes a super tight press fit.
- bend the inner tube slightly
- drill a hole through only the outer tube, and "spot" weld to the inner tube
- some combination of the above?
Thanks!
