New to the site, and 40' clear spans?
ishiboo
Oshkosh, WI
I found this site by mistake looking at some yellow PE pipe for gas line, and I have to say I couldn't be more excited to have found it :)
I recently purchased an 8-acre property, and will be moving from my 30x40' shop into a barn on-site. The barn is very structurally sound, but was used for chickens - it's a 40x100' barn with 4 floors!
I can't possibly use 16,000 square feet, even with all the junk I have, so one idea I had was to convert half the barn (40x50) into my new garage by removing all of the floors on that side of the barn. They were added after the fact and are non-structural.
The hayloft, though would be a great mancave, and I was thinking about re-building the fourth floor over the garage, which would give me ONLY 30' ceilings in the garage, and make room for a future 40x100' mancave :) Only issue is I would have to clear span the 40x50' area. Any thoughts on the best/most inexpensive way to do this?
Could be quite a cool setup - parking/large work space in the first ground 40x50, another 40x50 connected to that with 9' ceilings for my workshop, and then two more 40x50 floors for storage/workrooms on the way up the steps leading to the mancave...
bazzateer
Watford, Great Britain
I hate you with all that space!
I think you need to post some pics to help with this. That sort of span is going to require some serious timber or even steel I beams.
Did I say I hate you? :thumbup::lol_hitti
haugy
Nashville, TN
I can't help you. For some reason jealousy doesn't let me help people.
But I'll try. If I'm understanding you right, you want to open up one half, and leave the other somewhat with a 4th floor? And on the open half, how do you span the 40'?
Is that right?
You can get trusses built for a 40' span. That wouldn't be too hard to do, but what is the current building structure? I can't seem to picture what you're describing.
I
ishiboo
Oshkosh, WI
All good info, thanks.
I will take pictures tomorrow, I was out there today but it was rather dark. Interesting being in a 110 year old barn with 50mph winds, but if it hasn't fallen down or even got out of square in the last 110 years, I don't think it will now :)
It's hard to capture a picture of the space due to the floors, but yes. I plan on taking out the floors on one side making that my workshop. But I'd like to keep the "top floor" continuous.
ket-tek
That smells like 110yr old chickens? :)
Hang out on this site for a few more months and you be designing an addition!
As mentioned TJI's or Truss Joists could span 40' no problem.
I
ishiboo
Oshkosh, WI
Suprisingly, it just smells like old barn... not bad at all. The upper floors were added to the barn at a later date, and while they're still old (not dimensional lumber) you can tell the construction difference. So chickens may have been addition in the last 60 years :)
TJI's, trust joists and LVL can do the 40' span, but I get the feeling there would be a decent amount of "bounce" to the setup. I'm almost wondering when all is said and done if I would be better off having a steel frame built.
One cool thing is, with most setups, I could remove only the top floor and then use the remaining floors (with appropriate holes cut) to assemble the "new" walls and floor, and then remove the floors inside when things were complete.
Pics coming tomorrow.
mopar4wd
East of the river CT
A friend of mine used to work in a converted chicken barn. Link to the company here
http://www.sixrivermarine.com. You can see the main work shop in a few of the pictures on the site. They actually opened up about 2/3 width full height then left a balcony on one side. They would then extend staging from the balcony right onto the decks of the larger boats they were working on. I went in there a few times and thought it was a pretty cool setup.
I
ishiboo
Oshkosh, WI
That's interesting.. but I can see why.
Last year, all winter was spent redoing the interior on my 29'. Prior to putting the boat "away" for the winter, I built a work platform complete with stairs to make access to the boat easier.
Turns out it was absolutely ESSENTIAL. I would never have finished it having to carry cabinets, carpeting, tools and everything else up and down a ladder and making the transition 30 times a day.
Pics coming soon.
I
ishiboo
Oshkosh, WI
Pics! Do not despair; I am no ignoramus, I realize the scope of this project :) The barn is structurally sound; the floor sagging you see is a combination of the fact they were added later, and the fact that the original 1st floor posts rotted and were replaced about 2' away from the ones which rotted - not over a foundation! Those also rotted. All floors need to be leveled.
Overall:
Ground floor:
I
ishiboo
Oshkosh, WI
Fourth floor. The side with the open boards is not sided with steel like the other 3 sides. My plan for this would eventually to put some huge windows on this side, with a chimney/gas fireplace in the middle. This floor would be the "man cave" floor. Decent view until its subdivided in 10 years.
The beams at head-level can be moved, they were there to keep the barn from racking, but that was prior to the interior floors being added. So they would be relocated to the "top" for appearance purposes, and new tensioners added right below the floor.
Looking back:
View from the "window wall":
Huge contraption for moving bales, I assume:
I
ishiboo
Oshkosh, WI
The photos do not really do justice the scale. 2nd and 3rd floor are low ceilings, but they're at least 7-7.5'. Each floor is 40x100, or 4000 square feet :) Slightly less for 3/4 as there is a bit of roof pitch, though quite steep.
I'd say the ceiling on 4th is at least 20-25' high in the center.
Farm house from the 2nd-floor drive up:
Holedgr
MY F%$KING LOT IS 45 X 117'!!! Whatever dude.....have fun with your space issues....:lol_hitti
danski0224
Near Naperville, IL
Best and cheap, eh?
Hmmmm... 2000 sf
Guess it depends on your desired live and dead loads.
I bet steel trusses with a 4" pan pour will be cheaper than TJI's. Either way. the walls and foundation have to be strong enough to hold it up.
I
ishiboo
Oshkosh, WI
Best and cheap, eh?
Hmmmm... 2000 sf
That's one cool thing about this barn - it's straight as can be. If it's settled over the last 100 years, its done so evenly!
The walls are concrete but I have a feeling it is over the original fieldstone/mortar. Removing 3 floors of wood, I think whatever the replacement is, even if steel, is going to be half the weight. Currently each floor is comprised of a 3"x9" every 16". Not dimensional - a true 3"x9". Plus the lateral joists, columns, etc... and the fact that the floor is inch or inch and a quarter solid hardwood, I have no doubts the new 1-floor replacement will weigh less :)
Hope it doesn't tip over!
I'll have to look into steel, that was my first idea. Bolted steel would not require the lateral stabilization I may otherwise need.
SPDMETL
Dammit, you made me forget what I came on here to post ! Envious like everybody else...
twostory
Duluth, Georgia
If the floors are made from old wood, there is a market for the raw material.
People make flooring and other visible structural wood to use in new homes. The old growth wood is valuable, as you can not find any 100yr old trees to cut down anymore.
I
ishiboo
Oshkosh, WI
I know... It was a foreclosure - its a miracle that they put the steel siding over the barn board rather than removing and selling.
I'll be keeping all the wood with the barn, may seem silly to some but there is no way to replace it once its gone. The beams will be relocated in the mancave for aesthetics, and the rest will be stacked and strapped with some sort of spacer so it stays dry.
RPH
Michigan Thumb
This project is ideal for the aussie product from lite steel beam. A few years ago I installed the induction welder on the line in Virgina. Never heard of it but was very impressed. Two or three guy's could install the needed beams with out crane. There designed for basement beams, large door headers and can be shipped 40' long. I know they were working on longer lengths but were still setting up the lines. Just check out the web site. Nothing ventured, nothing gained ? No, I don't work for them.
http://www.litesteelbeam.com/
All in all a great place to start and the finished product will be awesome. Got to love the old barns.
