Hydra Lift 2 post for 1K good deal or?
healing
Looking at a used Hydra Lift 9000 lb. two post asymmetric lift. I will be using it at home/farm shop. I have 16' ceiling height and want to use for 3/4 ton diesel pickup and smaller vehicles. Any pros or cons of this lift?
Thanks.
H
healing
Forgot to mention it says made in Canada on it. This should give me peace of mind right? as opposed to China stuff?
PxTx
Subs of Philly
The best used lifts come from the 1980's. I honestly don't have a preference between a generic "Canadian" lift which may or maynot use components manufactured overseas and one comming directly from China. I am not familiar with the particular brank you mentioned. The best part is you can inspect the lift to know how the seals and various other components are holding up. I would imagine this lift would work well enough for just about anyone's personal space.
Deafautotech
Indianapolis, Indiana
you wll need know what pounds of your diesel truck to make sure it is less than 9,000 lbs lifts so lifter would not need to over load work and break something like line or seals. my works have 7 9,000lbs lifts and it is work goods but i had to check the dodge ram to make sure it can go on lifter or can't.
Ed ke6bnl
Agua Dulce, Calif.
I have an asymetrical rotory 9000 and lift my 1ton dually crew more times then I want. it weighed in a 6800 lbs. good luck and enjoy.
Aahz
Chicago, IL
Hydra lifts are notorious for trying to get repair parts. If it's their "screw" design, it will be even worse. Whenever someone wants to trade one in around here, we give scrap metal value as a trade. You can find a better value in a different brand of used lift.
ng8264723
Oakham MA
Get a used 80's vintage roary or mohawk. You can always get parts. They willl also never need parts
mce46
Hi can you pls share pictures? Im missing a lift block its behind a post that other end of cables attach to. Please thank
U
