Snap-ON KRL7011APDH: Rail Removal
bshpilot
I've got KRL7011APDH side cabinet and i want to "re-order" the drawers
to match the MAIN cabinet.
I cant figure out for the life of me how to remove the rails - i see NO
rivets OR screws in the rail "holes" that i could remove !
wreckercologist
cyber-tool hell
You need a thin tool to open up the tabs. I tried a putty knife, but had better luck with steel banding (like used to strap stuff to a pallet).
bshpilot
wheres the strap go ?
I've seen a video using a hack saw blade but that was for friction drawer removal
Ive got the drawers out - i want to release the slides.
glenmore
Los Angeles
This thread might help. It has excellent photos. I have a newer 40" box that uses this method of slide removal. I have a 15 yr old KRL that just has a single set screw to remove before removing slides. A compounding problem though is that you need overhead room to remove the slides, i.e. you need to lift up and out. So if my system is the same as yours and you wanted to move your third slide down, you have to remove the 2 above first and replace them in the same order.
http://garagejournal.com/forum/showthread.php?t=50143&highlight=removing+drawer&page=2
vc-onthepc
maryland
They are screwed to the inner cabinet using a 1/4 inch headed screw you have to move the slide to access it . 1 on each side . they are about 2 inches back from the face of the cabinet ..... you access them thru a circular hole
bshpilot
no, mine does NOT have screws
