foolishpride
Went to use my 20-year old Sears floor jack to put my dollies under my bass boat, and it wouldn't pump up. It would raise when I pumped the handle, but it would fall quickly back down in between strokes. I had this problem once last winter, when it was very cold.
I've never had a problem with the jack in warmer weather. I ended up taking a small propane torch, and heated the hydraulic cylinder up. The jack worked fine after that. Hiball, if you see this, does this sound like a rebuild candidate, or is this an easy fix? Thanks!
