So about 3 years ago, I bought both a 3/8" and a 1/2" Craftsman Thin Profile ratchet. The 3/8" has been trouble-free, if a little tight, but I'm going in tomorrow to warranty the 1/2" for the 4th time in 3 years. I don't misuse the tool. It never gets a cheater bar attached (I have a breaker bar for that). It never hits things (I have a hammer for that). It doesn't get left in the rain or exposed to abrasives. I really have no idea how I'm killing these things. The failure mode on the first 3 was the same. At light loads, when just working the nut off the bolt after it had been loosened, the direction selector would begin to revers mid-ratchet and jam the wrench until you flipped it back the correct way. Over time, this became more and more common until I would finally get fed up and replace the ratchet. This time, the ratchet acted just like it had done that again, but when I went to flip it back the way I needed it, the selector switch was jammed. Trying to jiggle it, it turns out the drive itself was jammed as well. The thing is just locked up dead tight, there's no play or movement in anything.
Anyway, I'm obviously fed up with the Craftsman ratchets constantly taking a dive and I want something that will be more reliable. The GearWrench ratchets come up repeatedly on this forum as well-made "middle of the road" ratchets; neither cheap **** not overpriced man-jewelry. I read enough about them to make me think I might like the Full Polish line of the GearWrench ratchets. However, two threads commented that, internally, the GearWrench ratchets are the same as the Craftsman Thin Profile ratchets. This makes me very worried that they'll die from the same problem as the Thin Profile ratchets keep doing.
Are they the same mechanically? Made to a better quality standard? Any reason at all to suspect they won't be as bad as the Craftsman?
