Common Wrench/Spanner Sizes [Metric]
dragonle87
What are the common metric wrench sizes?
I know 10mm through 22mm, excluding 20mm & I think 23mm
Thanks
DrkMtnDew
the majority of them are 10mm- 19mm. i have a set that goes to 32mm but it is full of holes in that 10mm- 19mm range, so it is only good as an add on set. :)
Interex
Dallas, TX
Yep, on every import car that I've worked on, the only wrenches I need are: 10 ,12, 14, 17, & 19
You'll have some rare cases where you'll encounter some small 8mm bolts or large 21, 23, and 24 but that's not very often.
D
dragonle87
I see, though I do work on alignments & brake bleed. Its just that I dont know the common sizes below 10mm and above 22mm
D
dragonle87
Yea I have encountered those sizes when I do alignments but 20mm & 23mm are rare. I guess I'll just use a 12" adjustable wrench to solve that problem
hultarp
Sweden
The standard bolts isn't 12 mm, they should be 13 :)
38D
Boston
On Audis & Porsches it will be 10, 11, 13, 15, 17, 19. Occasionally you will run into 16s and 18s. I don't think I've ever seen a 12 or 14.
williaty
The difference will be wither they're using DIN fasteners or JIS fasteners. The Japanese cars, obviously, are all JIS. This is the 7, 8, 10, 12, 14, 17, 19, 22 progression. The Germans obviously use the DIN progression of 7, 8, 10, 11, 13, 17, 19, 22, 24, 27, 30.
mtkst19
blitzburgh pa
all the newer germans are 16's and 18 mm happy. you dont see much in way of 17/19 anymore.
either way, a 10-19 set is key. Add on wise i would say a 7 and 8 for brake bleeding, and a 22mm for 02 or oil sensors. that should get you by.
Charles (in GA)
50 mi south of Atlanta
Every manufacturer seems to have favored sizes. My '99 Plymouth is loaded with 15mm and 10mm, but has other sizes also. I believe in having all the sizes I MIGHT need.
Charles
williaty
:headscrat Hmm... that means they've switched away from DIN to ANSI/ISO (7, 8, 10, 13, 16, 18, 21, 24, 30). I wonder why, being based in Deutschland, they aren't using the Deutsches Institut für Normung standard anymore :confused:
wafrederick
Holton,Mi
Domestic cars use lots of 8mm,10mm,13mm,15mm and 18mm.22mm is used on 1988 to current fullsize Chevy trucks,the lugnuts including fullsize vans.Some Japanese and Korean cars use 21mm for the lug nuts.
dwm
Southeast Michigan
My own car pretty much runs the gamut from 8mm to 18mm. 16mm and 18mm on suspension parts. 19mm on a couple of things. 32mm for the cooling fan, 36mm 12-point for the wheel bearings.
Buying a set, I'd get 8mm to 19mm (all of 'em, though 9mm can be skipped). Above or below that, buy as you need.
mtkst19
blitzburgh pa
im not sure what exactly why they did it or what they follow. to me there is no rhyme or reason.
from what i can remember off hand--
i would say w/ the advent of the a4/a6/a8 line in 96 is when audi started switching sizes.
Same can be said for vw. Around 95/96 is when they started changing stuff. early 93-95ish range models were similar bolt sizing as say mk1 and mk2 vw's. then it was like bam, we are changing.
muibubbles
nj
i have a mazda and i can pretty much take the whole car apart with a 10, 12, 14, 17, 19....
wxm
Are some of the bleeders 8mm? IIRC, my Nissan Maxima is 8mm and 9mm for the landcruiser.
rick carpenter
Huntsville, East Texas
I think Italian cars use the Fibonacci progression of 0, 1, 1, 2, 3, 5, 8, 13, 21, 34, 55, 89, 144, ...
shoggoth80
Seattle
I see a lot of stuff, and common is in relation to what you work on. I wrench on a bit of everything.
8, 10, 12, 13, 14, 15, 16, 17, 18, 19, 21, 22, 24 are the ones that I see a lot. Predominantly 10,12,13,17, and 19, but the others pop up enough.
I see 19, 21, 22, and 24 a lot on front end stuff.
wafrederick
Holton,Mi
GM,Chrysler and Ford use 8mm,10mm,13mm,15mm and 18mm a lot.Use 21mm and 24mm for the bigger bolt head sizes a lot.If their cars are built by any Korean or Japanese car makers,use 8mm,10mm,12mm,14mm,17mm and 19mm.20mm is used on GM fuel filters including some a/c lines.
BK13
PDX, OR
So, are the various standards just the progression of sizes, and a 13mm is a 13mm, or do you (ideally) need a JIS set, a DIN set, and an ANSI/ISO set?
Or am I just reaching too far for a justification for more tools? :willy_nil
joel63
Central FL
12-23-2010 07:27 AM
I learn something new everyday on this site.:lol:
'71 VW 1302
Brantford, ON
Slightly smaller fasteners = slightly less steel. It's a commodity bought by weight, not by the unit, so it's all about $$. Better steel chemistry means the slightly smaller fastener is up to the task.
Less weight is also part of fuel economy. In time cars will meet the CAFE requirements, but the material science costs will outweigh the dollar savings from reduced fuel use. The reduced emissions will be real and measurable, but costly.
Paul
tradesmanschoice
Cambridge, UK
According to murphy's law, you'll never have the size you actually need. So IMO it's best to buy a basic 8-19 set to start off and then get the rest on an as-needed basis.
However, if you can't afford any delays, then you'd best get the widest ranging good quality set you can afford.
Cheers,
Mark.
Gmonkee
Melting pot countries like Mexico you tend to need them all.
We have S. American products showing up as well as Euro. N. American and Asain imports, some of which have domestic manufacture as well just to keep us on our toes. The fastener standards vary a bit.
The bolt head sizes tend to vary a bit to where a 14, 15mm or 9/16" wrench could do better than whatever size it is supposed to be. I stopped worrying about the numbers and use the one that fit best.
My observations were Germans run more exact and Koreans a tad small or ever so slightly tapered. And then consider a bolt may have been replaced somewhere along the line for some reason. Its a crapshoot as the cars get older.
winlinmac
USA
I apologize in bumping this thread. What are the common wrench sizes used in Audi / VW cars?
Fugio
On bicycles, 99% of them will be 13, 15, or 17mm. And maybe once in a while you'll need a 32 or 36mm. Park makes a combo for that.
Just FYI.
