How to fix this? SK Ratchet
5toes
I have this SK 3/8" drive ratchet I got from my grandpa and it needs some help. The ratchetting mechanism is very stiff, its very hard to turn without a socket on. Everything else about is good though, it switches directions with ease.
Do you think it just needs new grease or? I figure I can take the back off (dont know how though) and soak it in some mineral spirits then grease it up.
Fedwrench
Valley of the sun
You should be able to remove the gear assembly by removing the snap ring. You could then spray the lube of your choice on the gear to see if that improves things.:beer:
oak_park
Chicago
Nice ratchet. Its often called the s-k Frankenstein because of its head/neck pegs and it has no part number on it. Like others have said, remove the snap ring, give it a little lube. I think its a 36 tooth ratchet, so its not fine fine tooth. Its kind of rare, not as common as sk's regular 45170.
5toes
Oooh good find for me. I found it in a case that holds like 7 sockets, but couldnt find where he kept his sockets!!!
haha so how do I remove this ring?
Scout Driver
South Dakota
In your second and third pictures, the ring is visible. As you can see, there are a couple tiny holes in the end of the ring. If you don't have a snap-ring pliers, use a needle-nose pliers to draw the ends of the ring (where the holes are) together. This decreases the diameter of the ring, and lets you lift it from the ratchet. It might take a little wiggling to get it free.
Scott
gatewaysysop
Arizona
Please, get some more pics of the inside of this thing once you have it open. I'm sure many people would enjoy some detailed shots of the inside of one of these, because I don't think anyone has shown it before.
5toes
I GOT IT OFF! Haha I just used two craftsman slotted screwdrivers and pushed with it in a vise. Pics in a couple minutes
gatewaysysop
Arizona
Can't wait to see!
As for why they're so special, I think it's it's more about the fact that they are not easy to come by and very unusual looking. I hope I can snag one someday. :beer:
5toes
Haha okay getting my camera. The design, compared to say another ratchet (though I have not seen one taken apart) appears bulletproof
5toes
Here they are. I uploaded them via Min.Us... I highly recommend this picture
host.
Anyways all pics in this thread were shot on a $80 Nikon Point n Shoot my Mum picked up a few weeks ago.
sk farmer
nd
dry as a bone. clean it, lube it and put it back to work. no wait, send it to me and if i get it going i will send it back. (i'm looking for one also!)
bonneyman
Desert SW
Here's some pics of a no-name (Wright?) 1/4" steiny I had:
5toes
Its so dry because I cleaned it with some degreaser. It had some dirty grease though when I first took it apart.
So would motor oil be ok to lube it back up?
gatewaysysop
Arizona
Since it's coarse, I would suggest the Super Lube stuff that you can get at HF or Amazon or even eBay. That's what SO uses (even says so on the little packets they send with rebuild kits) and I've put it in several of my coarse tooth ratchets (old Proto, for example) and it worked wonders. Only takes a light coating on the gears and pawl and it works really well.
sk farmer
nd
red lube of love or rrl. permatex engine assembly lube is the stuff. use sparingly, not merk style.
5toes
Oh Okay. Haha I also read on here about wheel bearing grease or something like that?
5toes
Yup. Same. Haha your box is longer, I was like wtf... then I found out it 3/4" drive
So can anybody date this ratchet?
And what about that wheel bearing grease?
5toes
I might have wheel bearing grease... but I doubt it. My mum said I have some white lithium stuff. I do know for sure we have some coastal all purpose stuff. Would that work?
Scout Driver
South Dakota
All purpose grease would be worth trying. If you don't like the "feel" of the ratchet with a certain grease, its easy to take the ratchet apart, clean the parts and try something new.
Scott
Joe Mamma
Personally, I wouldn't use white lithium grease. I think that stuff breaks down or separates when it gets really old.
Joe Mamma
5toes
Coastal All purpose grease is in. Its smooth, not loud at all. My Dad has a late 80's Craftsman Ratchet set, 1/4 3/8 and 1/2 drive. This is smoother than any of them.
Not loud at all. The grease is red, similar to RLL it looks like
Scout Driver
South Dakota
Good job, 5toes. :thumbup:
Scott
dimwittedmoose51
Cedar Falls IA
I'm only getting in on this thread a few years late, but I just picked up a 1/2" Frankie at an estate sale last Friday and the really thin handle had snapped off about 5" fro mthe ratchet end. I couldn't find the other half anywhere i n the house or basement, so I just ground off the jagged end and made a stubby out of it.
I had not trouble getting the snap ring out using a Chinese(God-forbid) pr. of micro needle nose pliers that had really deep teeth to them. What I found was either a testament to SK's metallurgy or how stupid someone can be with a hammer or cheater pipe. 2 or 3 rat teeth on the drive piece were broken and the teeth on the Frankie part were "altered". With the metal chips out of the way, I cleaned the whole mess(green can of Brake Kleen) and then coated the moving parts with Anti Seize compound. As others have said, the rat is rough but the fact that the handle snapped and there was little damage to the gear teeth I find fascinating. I'll keep it in the tool box and see if a repair kit exists, but won't hold my breath.....
DM&FS
