Flex head v. Roto (swivel) ratchets
ajchien
Los Angeles, stuck on the 60 freeway.
I'd like to get myself a longer handled finer tooth ratchet with a flex or roto head.
First question is: are there any advantages to a flex head vs. Roto head? Or are they the same?
Secondly, do you guys have recommendations? I'm always on a budget, so I'd tend to stay away from the truck brands (although if you recommend it, I'll see if i can find one at a swap meet)
Danglerb
SoCal
I use them for different stuff, the roto a lot of light fasteners where I switch from speeder to torquer, flex head is more an access thing where I need to reach in, but lack clearance for a non flex handle.
mrholeshot
MEMBER EMERITUS
I prefer the Roto head. Allows you to push the socket onto the bolt one handed. While a locking flex allows the same it doesn't allow the handle to move once on the bolt. Yje only downfall is it's a little wide in the hips. Very rarely an issue but enough to keep a flex head as well. If I could only have one it would be the roto head
littlekillertoad
Orlando, Florida
If it were just one or the other, I'd go for the roto ratchet.
I bought the gearwrench roto ratchet a couple years back and it's been good. I've not had any problems with skipping teeth or reversing and I haven't been nice to it at all. If you're just a shade mechanic, I'd go for one of those. I'd also recommend the SK roto ratchet. It's run you a little more than the gearwrench but it's a nice piece of equipment and it's made in the US.
