My personal product review Fein Multimaster
toytech40
small town in SW Kansas
Recently I asked for input on here for which oscilating multitool was best from your experience and got alot of good advice and responses, thank you all. I had a flooring project coming up so I finally pulled the trigger and bouget the Fein Multimaster manufacturer refurbished kit from CPO for $259 delivered. CPO did a good job and it was delivered promptly. Did my flooring project this past weekend and used it to undercut 6 doorways and several other cuts that no other saw would do and it performed flawlessly. It made the job go smoother and more enjoyable. Yes I know that replacement blades can get pricey, and some complained they didn't last long. I can say I used 2 different blades on this project, one more then the other, and both are still cutting just fine, I also followed advice given by several on here and did not force any cuts and let the tool do the work. The cuts were still made in a timely manner and with little/no strain on me. All in all good product(yea a bit pricey if bought new) but well worth it. Also CPO does excellent Job as well, will look at them for future purchases.
So that is my 2 cents worth, do with it what you may.
qwik
savannah ga
had mine for 2years one of the most usefull power tools ever, but the cord is little to short........
Vinko
Los Angeles
I've been thinking of one as well.
But I'm also weighing getting a sander with dust vac. Either a Fein or Festool, but I don't want to spend that much dough without using both first.
Monte
Germany
if you need a sander maybe this one ?
<object width="640" height="385"><param name="movie" value="http://www.youtube.com/v/N_CTt_OGJlA?fs=1&hl=de_DE"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/N_CTt_OGJlA?fs=1&hl=de_DE" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>
cashishift
Omaha, NE
Festool is nice, there is no doubt..
but jeez are they proud of that stuff.
dsan
Woodcraft nearest Los Angeles is in Stanton which is quite drive even on a Sunday. If Vinko is in Los Angeles then maybe Eagle Tools right off San Fernando road or Rockler in Pasadena.
sprkt01
Long time lurker new to post. I love my multimaster. The blades are high, I have found blades for the bosch saw fit and are cheaper. Also i think dremel blades will fit also. I have tried Craftsman but need to make an adapter to make them fit proper. Thanks
Vinko
Los Angeles
I just noticed Anderson Plywood in Culver Sells this stuff.
I'm getting closer to getting something. Looking at the C-26 vac. and a 5" sander. Ultgar has been quite helpful and I might go with that combination and then get the delta sander (maybe a dedicated one instead of the Rotex 90 pictured in the video). It's something I've wanted, and I can see using it around home a lot, and even around work where a lot of things need to be repaired or refinished including windows. Not that it's a priority.
