diesel research
Not anymore! Plenty of power now. The reiview is not completely fair comparison of any other product, nor is it complete and concise. Just some initial findings.
The old guns were a IR231C (classic) and a IRSLTG-232 (thundergun). These did the job although far from optimally.
The job was installing new fresh 15/16ths fine thread CAT D4 track bolts. NEVER attempting to loosen them. Anyone familiar with tracks, knows that is a waste of time. You burn them off and start fresh. The particular run of track eats approximately 60 bolts per night.
The air supply setup is not optimal. It involves a very nice IR compressor, ~50ft of hard pipe and ~200ft of red 1/2" goodyear hose with about 4 quick connects in between. Very wet air with a constant mist of water escaping the exhaust.
A new Aircat 1600-TH arrived to retire these 2 guns. Quick description states:
All I can say is wow! First impression everyone notes is the twisting torque while free speeding. Kind of like revving a car engine in neutral and seeing it rock. Significantly more twist, although this is neither a benefit or drawback, just an observation.
Once used, I note that it runs these bolts down amazingly fast with minimal hammering. Save a lot of time here. The composite handle does not get freezing cold. It also sounds much like a cordless impact. The SLTG and 231C scream like a banshee, and have that familiar F1 car sound we all have grown to love. This really doesn't have much noise at all, and saves my ears.
It is surprisingly well balanced and light. This is very important since installation of these bolts is over head/vertical, requiring standing on a ladder, holding the gun single handed out at full arms length. Even with the additional weight there is less fatigue since it requires less time.
It definitely has some serious torque as well. Within about 4 minutes it had sheared a brand new proto impact adapter.
I could see this used in many applications where a 1/2" IR-TImax works but hammers and struggles for a few seconds.
No clue on longevity, but suspect others will destroy the composite housing since they have a tendency to like to drop things from a height of 6-8ft
Features and Benefits:
* "Super Clutch" new patented design with ball bearings between the hammers
* 1400 ft. lbs. loosening torque and 200-1400 working torque
* 7.9 lbs Lightweight composite body
* High performance Tuned Exhaust to minimize noise, dust and debris
* Ergonomically designed handle
All the power at half the noise! The superior mechanics and internal mechanisms of the AIRCAT® impact wrench includes high-quality bearing surfaces, air chambers and turbines. The patented exhaust muffler/filter technology reduces the level of noise while retaining more power and torque. A quiet, powerful tool ideal for shop or home applications.
