My 19 X 19 shop redo- post quake update!
I finally decided that as my 69th is rolling around, it was time to stop crawling around on my back in my gravel drive whenever I needed to work on my car. A few years ago I rebuilt a Jag XJ40 subframe and differential doing that, and now I have some suspension and other work to do on my Porsche 928, but this time it's going to be out of the weather, under a roof, and on concrete!
I have also let my little attached garage/shop slowly turn into storage space, which meant a major cleanup before and after I could get anything done. Time for a complete redo. A major impetus for doing this redo, besides my advancing years, was a mention of GJ on Rennlist, the Porsche list I belong to, with a link to The 12-Gauge Garage. I clicked, sat, and since then have spent many hours on this forum getting ideas. And I'll give credit for them as I describe the project - I owe some guys here real thanks.
For background, when we bought this place a dozen years ago only one half of the "garage" had a concrete floor, the second half was dirt. The "doors" were sheets of plywood painted black with no real hinges. in other words the addition had never been finished. First thing back then was to pour concrete in the second half (4" 3000psi - glad I spec'ed that now), and finish the wall and door. As a shop I did not provide a garage door, just a man door.
Over time got all my tools in, hung a lot of "temporary" wiring, installed air and vac lines, and then just let things pretty much go to hell.
So here are some pics of what I started with in January-
View media item 21851
View media item 21852
View media item 21853
View media item 21854
What a mess. First thing to do was make plans. These boiled down to insulate, finish the walls, raise the ceiling, rewire, replumb air, and new dust collector lines. But first of all, replan the layout. This had to be done to change the area from shop to shop + garage. To do this I needed a graphics tool - I've cut out cardboard and moved it around on graph paper, but that technique could not accommodate everything I needed to do. Over the years I've used a few programs, but for this I used something very simple (and free - you'll see I'm pretty cheap) Open Office Draw. It is a simple program but has some good features, the most important to me is its "Layers" function. This allows you to create a design in multiple layers which you can view in any combination you wish. First of course, the basic layout of the area, with new garage door and relocated window, then a "catalog" of all the tools and storage that needed to be fit in, done as scale drawings of their footprints, coded tan for powered, blue for other:
View media item 21857
View media item 21855
Next step, try to fit it all in. Besides making room for the 928, other considerations included separating the woodworking and metalworking areas, reducing storage to just what I use in the shop, heat and lighting, finishing the floor,and allowing for a MaxJax in the future if I get lucky - that's why I'm glad I spec'ed the new concrete the way I did. And my thanks to everyone here and on Rennlist for their discussion of this product!
Part 2 will about fitting it all in, and the first steps in getting it done. Thanks for reading, suggestions, comments, criticism, laughter - all appreciated!
