Just wanted to share something I learned this weekend.
I've spent incredibly too much time researching workbenches over the past two months. I have just moved to LA and I'm in the process of outfitting my new 19x19 two car. Since I am tight on space I am trying to build a bench that serves a ton of purposes.
Anyway, I had originally planned to notch some 4x4s as legs. While I realize that sistering 2x4s is quite easier, I really like the look of a 2x4 frenched into a 4x4.
Now, I knew two 2x4s sistered would be stronger than a 4x4 since you have opposing grains, what I didn't realize is that 4x4s are actually cut from the core of the tree which is the weakest part of the tree (thanks Dad for the lesson in lumber). So a standard 4x4 is actually much weaker than two 2x4s side by side. I bring this up because i have read a lot on this blog and no one has ever mentioned this. The only thing I have seen mentioned about the difference in doing 4x4's vs 2x4s is the ease of sistering vs notching.
So, the moral of the story is sistered 2x4s are much stronger than 4x4s. Granted 4x4s when used vertically are still rather strong for most applications, but should never be used horizontally for something structural.
but if you make a box column out of plywood...
