Milton V style hi-flo vs. 3/8 T automotive
bchee
Texas
What do you guys think about converting from the milton V-style hi-flo plugs to 3/8" plugs.
I measured the ID and the 3/8 plug is actually smaller on the threaded end.
Has anyone done this? I wasn't sure how to search for this because "3/8" doesn't bring up what I'm looking for.
I wasn't sure how to interpret these 2 threads:
http://www.garagejournal.com/forum/showthread.php?p=636143
http://www.garagejournal.com/forum/showpost.php?p=535666&postcount=70
The 3/8 plugs and couplers are definitely bigger and heavier.
By the way the plug in the picture is the Harbor Freight copy
http://www.harborfreight.com/4-piece-hi-flo-male-plug-set-65894.html
shampoop
SW Washington
Hope they aren't like the 1/2 plugs and almost impossible to disconnect under pressure?
The 3/8" automotive "T" style is all i've ever used. Plenty easy to remove under pressure.
edit: i meant 1/4". I can't imagine the 3/8" ones being significantly harder. The 1/4" ones are extremely easy every time.
diesel research
gulf coast, TEXAS
We have 2 types of drop lines. 1/4" and 1/2". I'd love to tap into the 1/2" line to utilize more air power/less line loss, but they are a royal beast to work with. Night and day difference between 1/4". Last employers setup was same way, so I have to wonder how the 3/8 is.
The difference was the requirement to push in to release, where the 1/4" just kinda slide the collar back and everything pops off.
bchee
Texas
U guys didn't really help me at all.
I'm thinking about switching to the 3/8 cuz my local home depot has the plugs on clearance at 50 cents each (steel) and of course they flow more air. The couplers are also on clearance (< $3.00).
The nice thing about the milton hi-flo v-style is you push the plug into the coupler without having to pull the sleeve back. Removing it is a little tricky but I think it's only because the knurling is not very aggressive, and I don't think it's related to the pressure.
The HF copies of the milton v couplers have 6 balls inside.
Bo Heck
I had the HF copies and the knurling sucked, it was near impossible to pull the collar back, and they leaked. Switched to Milton V style, knurling was much better, on/off is no problem, no leaks. This was 1/4"
cglasgow
Can't speak the toward the 3/8", but I always used 'A' style because of what you mention -- just push to connect, and they come apart easy. Of course I didn't realise to lately how little air they flow. I've since switched to 'V' style and I'm amazed at the difference in airflow. They're a little harder to connect (you have to push a little harder) and a little harder to disconnect, but other than that I like them.
If the 3/8" ones aren't push-to-connect (i.e. if you have to pull back the collar) I wouldn't switch to them, even if they were on clearance....
My $0.02....
chewy7
WISCONSIN
don't waste your money, the 3/8 are not much better. Stick with the milton v series and don't be such a wussy on how hard it is to disconnect.
Garage_Mahal
Get Prevost safety couplings. They relieve the air pressure and snap on with a gentle push.
bchee
Texas
I discovered a very simple trick for uncoupling. Push the tool (with plug) INTO the coupling and the sleeve pulls back with far less effort.
