MaximRecoil
Fine tooth ratchets seem to be all the rage these days, but it seems to me that a fine tooth ratchet mechanism would be weaker than a course tooth ratchet mechanism, all else being equal; plus I've read that you need to use light oil in them because grease interferes with their operation.
With a double pawl you can have the strength of course teeth, use grease, but have the small degree of arc that fine teeth have. For example, I count 82 distinct clicks (give or take; not sure if I counted perfectly) on my Blackhawk 34945A ratchet, with every other click sounding slightly different (because the clicks alternately come from two pawls). That gives 4.4°, which is about the same as the Snap-on Dual 80's 4.5°, but it accomplishes it with about half the number of teeth, and it also accomplished it ages ago.
