Dissection of the Pittsburg Pro Swivel Head Ratchet
gj67stang
Sycamore, OH
I recently picked up a 3/8" Quick Release Swivel Head Ratchet from Harbor Freight. Per previous discussions, this ratchet is deemed a good bang-for-the-buck value. One question remained unanswered: whether it could be diassembled to lube the internals.
Follow along as I dissect this ratchet:
Removing the T20 screw allows the split handle to be opened and the "head" released.
After chucking it up in the lathe and machining off the quick-release buttons reveals that this ratchet can't be disassembled without distruction.
The button and shaft is one piece. I assume they insert it into the 3/8" drive body, insert the detent ball and then peen around the ball to retain it and the quick-release shaft. (Sorry, the ball went to visit lost-parts-land as soon as I pressed the quick-release shaft out.)
We can also see a "flared" collar holding the direction lever to the drive body.
The flare tabs are broken off, allowing access to the ratchet internals.
Surprisingly, everything is lubricated better than I expected.
By my count, there are 72 teeth in this ratchet.
During this ratchet's first use, the handle popped loose, so I removed it for a bit of investigation.
The shaft is 0.465" in diameter and has two very small tangs and some glue to retain the handle.
5-0stank
PA
Nice thread/pics. ***** there is no way to lube it. I want to buy it, but I feel the "comfort grip" part of the handle is a tad small for my hands...wish it was an inch or two longer.
ToddyB
I bought the 1/4 and 3/8 due to the reviews here. My only initial complaint was the short handle which I now do not mind. When HF went Green I went and got a 1/2 to match the others. So far I really like them all. Worth every penny.
jjjrmx5
Cincinnati, OH
gj67stang:
I am so VERY happy that you have all of your clothing on in this pic because it so reminds me of an e-bay UK tea kettle for sale pass-along pic that makes you realize that chromed metal is reflective. LOL
Thanks for the write-up and the handle fault is quite sad. :thumbup:
HF has it's place , but not for tools that may endanger me.
airdale
Oregon
Hey, thanks for giving one up for the cause. Actually looks pretty well made internally, maybe not the most durable design, but for the price...
amolaver
looks like pretty good machining on the head and pawl. can you comment? i know you'll be able to tell us more about the machining from eye than the pics can convey. i wish it was able to be disassembled (w/o destroying it), but looks pretty well made.
ahm
cortez
Chicago
The paw has 17 teeth, which is 11 more than the generic Chinese ones, so I'm assuming it is at least twice as strong.
Like stated above not bad for the price. The handle should be easy to re-glue with gorilla glue.
Good investigative reporting!!!
G
gj67stang
Sycamore, OH
After I get around to picking up a new one of these, I plan to soak the drive end in some ATF for a couple days as well as install a different handle in place of the PittsburgPro handle (it just feels too small in my hand).
The machining (and chrome) is very nice overall. It's definitely better than raised-panel Craftsman's, not quite up to Snap-On's quality, but very good for the price. The direction lever does feel a bit cheap and the direction spring looks kinda skimpy for my liking, but for $12, I'll deal with it!
diesel research
gulf coast, TEXAS
those guts look likr the sk palm control, not like the wright, snap on or gearwrench guts which i think are a more durable design
:headscrat
While it does use the facom/sk type design, I am baffled by the suggestion that it "isn't as durable".
Just like another member pointed out. You have 23% of the geared head's teeth locked in at any one time, compared with about 8% on average.
That says nothing about the metallurgy of HF, or the specific dimensions, but to suggest the design itself is lacking, is a little strange.
KEH
Thanks for the test. I have one of those which I like, but haven't really used enough to challenge it. However, I bought one and gave to a mechanic who was doing some work for me(new clutch in a tractor) to keep my image good with him and to see how well the ratchet held up. After a few months he broke it. He is a young, strong, large guy and broke it while trying to loosen a 15/16 bolt, which is asking a lot of a 3/8 ratchet. It was broken in the square shaft that the sockets go on. Had to fool with it in the vise a little to get the socket off. The pawl was not broken. I took it to HF and got a new ratchet, not questions asked. The mechanic likes the ratchet and has been a little more careful with the replacement.
I examined mine and decided it must be pressed together.
Commeted about this to the SO man and looked at their similar ratchets. They can be taken apart by using a pick to unwind a snap ring, but the SO man said they just replaced the whole head and didn't carry kits for them.
KEH
Damian
Auburn, Georgia
I have that ratchet in the red handle and I like it a lot. I think I picked it up on sale for $10 @ HF a year or so ago and it's been a great tool. Nice smooth ratchet action and the swivel stays tight even with daily 8+ hr use.
TireTracks
Yakima,Washington.
I have a "powerbuilt" stubby version of that ratchet, with the head that can be opend.
I lik it alot, I just wish i wasnt so "stiff" when you ratchet it. Works great for confined spaces though.
dovco
I have and like the 3/8" and 1/4" versions of that ratchet. I don't like the plastic handles so I ditched them in favor of some knurled Aluminum.
dovco
I wonder if you could drill and tap that pin for a little button head screw. Then it could be disassembled and cleaned and lubed. Hmm.................
gungatim
west mich
I was thinking similarly, maybe there is a sweet spot on the top to drill a very small hole to add lube w/o disassembling it at all.
mtnkid85
dovco, I like your knurled AL handle! Did you make it or salvage it from another tool?
dovco
Made them from Aluminum rod (3/8 ratchet) or tube (1/4 ratchet).
Here's the 3/8s:
dovco
IIRC the rod was 5/8 6061 and the bore was 31/64 drill bit.
Seems like I used 1/2 Aluminum tube for the 1/4 ratchets because the ID was already good for a press fit. It's been a while since I made the 1/4 ratchet handles, though.
I made a 3/8s handle for my buddy last night. He bought the 1/2 swivel head ratchet from Matco and is looked a lot like the HF so I went to HF and bought him the 3/8 ratchet for $13.07 (25% off coupon on my phone) and made the handle in about 30 minutes.
dovco
I told my buddy to just dunk it in brake cleaner when it gets dirty and shake it out a few times. Then, dunk it in ATF to lube it and shake it out. In his work environment a little oil seeping from a ratchet is no problem.
maico
England
The magazine load tests I've seen suggests it's almost always the square that shears first not the pawl teeth.
The strongest, from a design point of view, is the circular Facom type palm control. Lots of teeth engaging on a large radius.
dnschmidt
Phoenix, AZ
That tool is manufactured by William Tool company in Taiwan and is used by many companies including TOPTUL. This is the only version that cannot be rebuilt. The two TOPTUL models that use the exact same mechanism have an allen screw in the middle instead of the quick release button. They are quite strong as there are many teeth that contact the outer rims perimeter.
For what you're paying for this ratchet it's an exceptional value. With respect to the handles coming off all you need to do is epoxy them back on and they stay there forever. I use golf club shafting epoxy but any two part epoxy works fine. System Three 5-minute works equally well.
The TOPTUL ratchets can be taken apart very easily and I lube them with Superlube but the suggestion to dunk the head into ATF works equally well. Not a big deal actually.
Mr_B
Reading
we get the same taiwan ratchet as pittsburg with the release button (no screw) but it has a rebuild kit listed. it under laser tool brand and identical besides handle inlay color .
ratchet p/n 3520
repair kit p/n 0469
Mr_B
Reading
I just picked up a 3/8 & 1/2 of these in clearance for 15usd, got heads half covered in atf bath in hope of good fluid entry after couple day soaking and making them feel super smooth. strippable taiwan ratchets come out buttery smooth with light coat of lithium grease and few drops of quality atf .
Think will lathe up a couple alloy knurled grips and do them 2-3" longer as handle design and length not best as is .
mudflap
cincinnati,ohio
Thats what i did..didnt help the horrible back drag..but its the only swivel head i have thats quick release...so i like it better than some others.
dnschmidt
Phoenix, AZ
That's a William Tool design. TOPTUL, and a bunch of others, get ratchets from this primary manufacturer. I think this is William Tool's #1 seller.
