floor to wall seam
dtzackus
I am getting information to redo my garage floor, I want to water proof my garage since my wife loves to pull in the garage without pushing off all of the snow and then I am left with a mess, then I noticed the water is running under the wall, creating even a bigger mess.
Do any of the DIY coatings give you the option to do this?
Thanks in advance, Dan
Cabby89
Depends on the coating and look you want. Simple solution would be some vinyl floor molding that will kind of resemble a cove base setup but a bit easier for the DIY. The other option is something called SpeedCove. You basically then are coating a few inches up the wall and create a smooth transition to the floor.
Picture I pulled of their site.
slickgt1
I believe Laticrete makes a water-proofing paint. I've seen tile guys use it. Thick blue ****, costs a lot. He puts this material, looks like fiberglass mat, then paints it with that blue stuff. Lowes sells it. So he did all the seams in the shower and the pan. Plain painted the walls with it without the mat. I bet $50 with him that water would go through. ******* put a garden hose to it for 15 min. I was not happy for loosing.
