keepup's airplane factory and tribute to Yamaha
keepup
First things, first.... Gotta give props to the primary inspiration for my layout. When I saw what XcYZ did with his shop at http://www.garagejournal.com/forum/showthread.php?t=45022 as you see below, I knew it right then. Gotta do it!
Ok, before I build this.....
I gotta build this.....
Yes, I will be painting the triple tuning fork on the epoxy floor...
Yeah, she's a work-in-progress, a labor of love, and a fun project. Much left to do including drywall patching (from wiring and blowing in insulation), mud & tape, paint, epoxy, running compressed air lines, new larger compressor, etc. Never stops. More to come on how I got to this point. Hope you enjoy. First, a few more pics of current progress.
Poker table and air cleaner hanging from the ceiling....
Alright, now for the build process in the order it occurred: wall & door separating the 1-car from the 2-car, whiteboard, blowing insulation behind the drywall (no pics), furnace and flue, ceiling cabinets, desk/media center.
Building the wall and door:
Lesson learned from building this wall. Code requires the garage floor to slope toward the driveway for drainage and I forgot to account for it. So after installing the door I had to modify the jam so the gaps around the door would be correct.
The opening above the door is for the through-the-wall air conditioner.
Door frame assembly. A little note about this door. I got it for $40 at the Habitat for Humanity Restore. With it's double pane and insulation I'm guessing it's probably a $400 door perhaps?
All kinds of creatures wanted in on the action!
Decided to add a built-in seat in the wall to sit and put shoes on and keep the kids' mud out of my Man Cave ("Mave" for short).
Drywall...
Could not get this shallow of an angle on my circular saw so I had to set up this hand saw guide to get the right angle for the drywall interface to the already existing wall.
Ten foot whiteboard. If I had to do it over again, I would have picked a smaller one. This one takes up too much valuable wall space. But I'll leave it the way it is since I now have enough storage elsewhere.
Like I said, no pics of blowing insulation inside the walls and above the ceiling. For the walls, I used a 4" hole saw so I could save the remnant and put it back in place for easier patching. Here's a tip when blowing insulation. I actually blew it twice. First I ran it through the blower into a huge fluffy pile in the middle of the garage. This eliminated the possibility of clogging and I think improved the R-value by making it extra fluffy. Settling after the fact probably reduced the R-value a little but it was really nice not having to deal with clogs. I used cellulose. Didn't want to hassle with airborne glass particles. Another thing, I got the blower rental for free when purchasing a 20 bag minimum at either Lowes or HD.
I wish I had more pics of installing the flue and natural gas line for the furnace. That was a fun job and worked out beautifully. Was a bit nerve-racking to cut a 14" hole in a perfectly good roof but that worked out well also and got it done just in time before cold winter temperatures. I found this furnace on Craigslist for $100. It's 100,000 Btu and heats the garage up to 70º in about 5 minutes. Whereas all the parts for the flue and gas line cost about $300. Kinda loud when it's running due to some rattling inside that I haven't investigated yet but nothing is better than working in a short sleeve shirt while it's blizzarding outside! Although it consumes valuable floor space I decided to install it on the floor to improve heating efficiency (heated air rises above colder air). Plus it would get in the way of ceiling cabinets above.
Ok, now the big job: Ceiling cabinets. I'm going to want lot's of closed storage when building the plane which keeps the majority of dust off the parts. When I saw XcYZ's garage, I knew instantly that's what I needed to build. I decided to go with 1 x 8 construction to keep the weight on the roof rafters lower. Needed 8 inches for the depth of the recessed lighting fixtures.
Step 1: Cut a small hole in the ceiling next to a rafter and tie the vertical supports into the roof rafters.
My son and my buddy Corey...
Next, set up the water level to trim the vertical support perfectly level. What I found was that the shelves were perfectly level but the roof and ceiling were not, causing more problems down the road with non-standard sliding door heights....
Trim next...
Ledger board and cross pieces next....
Framing complete....
Sheetrock.... yeah I have pushover friends who do all the work while I sit around and take pictures....
Wiring and decking.....
Let there be light!!!
Need some sliding doors.... queue the diamond plate....
Many more pics below..... keep scrolling down.
falconflyer04
Quebec, Canada
Subscribed!
I am also starting on building an RV-9A... but gotta finish the garage first! :)
But I already build airplanes at my job so it's more than a hobby for me....
dangle
MD
Nice setup, XcYZ's garage is a great source of inspiration!
Liking the roadie also, getting to be that time of year!
Omphaloskeptic
Ultima Ratio, Wa.
Subscribed! Great (multi) use of the space. Please document the RV build and let us know where we can follow it; hopefully, it will be right here on GJ.
expatriated
SE of Disorder
Sweet. Also subscribed.
My 6 year old is huge into Yamaha so we just repainted his red Cman cart to Yamaha blue.
What paint scheme are you going for the walls? I'm trying to incorporate some blue without going overboard. Maybe light grey up top, dark grey down below and a blue stripe around the room dividing the two.
Where are you getting all the diamond plate?
K
keepup
The Yard Store in Wichita is my source for many things including the diamond plate. I think I got a pretty good deal on two 4' x 12' x .063" polished aluminum sheets for $285. They are at http://www.yardstore.com and they have two locations: the surplus store just west of Washington on Central and the aircraft tools location at 10th and Mosley. They started at the conclusion of WWII to sell surplus aircraft materials, been at it ever since and you can find some awesome deals there. For aircraft kit builders they are an excellent source for tools and tool kits.
For the walls, I'm thinking about doing gloss Yamaha "blue" on the bottom, flat black stripe, and satin white on top with the cabinets on the ceiling blue as well. Not sure how well the gloss will work with the significant drywall patching necessary telegraphing through. We'll see.
K
keepup
Continuation of top post.
Media Center....
Whew!! Time for a break and some poker with the boys....
Every guy needs his own desk...... preferrably cantilevered.....
The message on the TV is PERFECT......
Here's hoping gussets will be strong enough joinery....
More sheetrock.....
3/4" MDF top....
Laying out measurements for the laminate top....
Time to fill the factory full of goodies compliments of Sams Club. Man I love the Seville Classics Heavy Duty garage cabinetry. It's built in China but is actually excellent quality if you don't mind the time consuming assembly.
TangoHotel
Georgetown, Texas
I have that same RV-7 print, but its on the wall at work. Looks good, are you also on Van's AirForce? I can't start my -7 until I move one more time for Uncle Sam.
K
keepup
Yep, Van's Airforce is one of my home pages. Don't post much there yet for obvious reasons. Hope to soon though! Yeah, I'd like to get a print for home and work also. All in due time.
Mr Mushman
Awesome garage keepup ! ! ! I love what you did with all the diamond plate and the Seville Classic cabinets, nice combo. Simple but very very nice ! ! I also used a few Seville Classic cabinets in my build and have a few places where I want to install some diamond plate. Nice addition and beautiful finish !
Congrats
6SpeedBowtie
WV / MD
XcYZ's garage is one of my favorites, and I really like your take on his design. Subscribed! Look forward to following this and seeing the finished product!!
projectPONY
Dallas, TX
very nice. I have a question. how high is your ceiling? I plan on doing the perimeter cabinets also as it proves to be a great storage idea.
SnyperBob
Illinois, USA
Excellent! Looks good. I would have put more cavities behind the TV. You could hide most of your electronics behind the TV. Stuff that doesn't emit much heat, and also has IR extenders built into them (cable box, media extender, xbox, etc)
Do you think it would have been easier to just frame the soffits before drywalling? Looks like you had to use a ton of extra wood to frame against the wall. I'm thinking about framing mine more how XcYZ did his....and drywalling after.
tinbender 66
Western Washington State
Nice work! I love the RV's. We have a bunch of them here at our local airport. A friend had a -6 so I got to fly it. Fantastic airplane. I'm sure yours will be a hoot with the kind of power you can use. We have a big EAA fly-in here (Arlington, Wa.) so maybe we'll see you one of these years!
I stole your desk idea for when it comes time to use it.
flybefree
Ohio/Kentucky
Subscribed.
I too hope you will docment your garage built airplane adventure. I hope to build one of my own some day soon. Great work.
Shaun
dipper
Rochester, NY
subscribed. looking good, great job so far. Boy you are gonna have alot of drywall to finish and paint :)
can't wait to see the garage build and the plane build!
K
keepup
Any new updates keepup?
The garage is on hold for 6 months or so while I get my private pilot's license. Put up a couple more Sam's Club wall cabinets, but that's it. I'll be back though!
10 ft ceiling.
Good suggestion on the hiding of the electronics behind the TV. In fact, that's what we've done in our master bedroom with the IR extender. Couple of problems I was somewhat concerned with though: first, still gotta have access to the Blu-ray player. Second, heat management was a concern with the recessed lighting back there as well. In fact, I have extra venting underneath to help. Third, I had to showcase my mad skillz with the diamond plate surrounding the media cutout! :beer:
Another good question on the drywalling after the framing. The difference between XcYZ's garage and mine is that he had an unfinished stud wall when he started. My builder had installed the drywall before we moved in so I had to frame over the top of it. Not a huge deal. Just run the ledger board.
Imitation is the greatest form of flattery! That's why we all share, right?
FRENCHBLUE72
Did these come with the gray storage bins?
strnge
MD
What did you use to hold your table up on the ceiling? Where did you get it from?
metalhead212121
I dont know about you guys but thats the BEST setup I ever saw for storing ramps!! I gotta steal that setup!
Dan in Pasadena
Pasadena, CA
Exploring XcYZ's garage - all the pictures are gone. BUT, I have a copy of the Garage magazine it was featured in along with the diagrams I assume the magazine made.
What the hell ever happened to this thread? Did he ever finish it?
