hofferwood
Wonder where it was made
Well my barley used rat started giving me trouble. Everything works fine, but the direction selector got real ****** last time I used it(hard to change dir.).
I was power tappin' a bunch of 10-24 holes, so it got old quick.
Here's what I found
Look a little dry??
Typical RH pawl setup
Here's the problem, usually the spring and plunger sit in a pocket in the selector shaft. This junk goes straight thru. With it being as dry as it was, the spring would "bind" on the body. (I'll get to my fix later)
The oscillator, attached thru to the air motor
The osc. shaft, you can see needle bearings down inside(also pretty dry)
Now what I did,(just some lube would have fixed it, but I had to get "fancy
Lopped 40thou off the plunger, shortened the spring and added a ball
Lubed her up with this
All done. Shifts like a Hurst competition+
Chuck
