i finally got tired of fighting with the adjustable table. Since there is no crank/gear mechanism for raising and lowering the table (and none available aftermarket), i came up with something almost as good, maybe better/quicker in my opinion. I put a counter weight (to offset the weight of the table) on it. I took the table off and weighed it and it was 24.9 pounds. Went to the local welding shop and bought a 33 inch length of round steel rod (1-7/8 diameter). According to my calculations, 33 inches would weigh just a bit more than the table so i could also use my small vice and still have it still move easily.
The round rod counterweight slides up and down inside the pole, so its out of the way. I attached a steel cable to the rod, then with two pulleys routed the cable out the top and over the belt, then down to the table, through the chuck key holder hole in the table, and clamped it off. I used 1-3/4 square tubing 1/8 thick and about 8 inches long to slide down in the pole. Welded a couple of stops on each side of it to keep it from sliding completely down inside, and a curved arm from a garage door opener to route the cable through the tubing, out and over the top with a couple of pulleys. With the counter weight, i still get over 2 full feet of table travel before the counter weight tops out (which is more than i have ever needed), and i can still swing the table completely around out of the way if needed.
I can now loosen the table knob, and move the table up with ONE FINGER! It actually takes more force to move it down now because of the additional counter weight i added to include the weight of my vice. No more fighting with the table!!! The best part about it is i didn't have to alter the DP in any way. No holes drilled, no welding done to the DP. Nothing is attached permanently and i can take it all off in less than 5 minutes. If you need better pics, i'll try and get some tomorrow.
Lemme know what you think!
