100 gallon propane tank...what regulator?
ponjohn
CT
Our Maxx heaters need 13wc or pressure.
Is this considered high pressure on the unregulated side (out of the tank)?
What regulators have you guys used?
John
mtwaterguy
I may be wrong here but I believe that pressure is determined by tank size not a regulator. My 200,000 btu heater will not run on the small tanks because of insuffient pressure. I switched to the 100 gal tank and it works just fine.
79firebird
Victoria bc
Depends on whats being used off it. my work was using a 500 pound bottle to run a inferad heat system then a small propane heater
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Most 100 gallon tanks have a built in regulator when you get them. The smaller tanks do not as in the BBQ grill tanks. With those the pressure is regulated by the tank size like mtwaterguy stated. The 100 gallon is a higher pressured tank and will have a regulator on it to reduce and maintain the pressure. Then the larger tanks from 250 and up have an external regulator before it goes to the source.
