10'x30' Mezzanine Engineering Glulams
472scout
back 40
I'm about to order the lumber to build a 10' wide x 30' long mezzanine along the back wall of my 30'x40'x14' pole barn.
This will be for general storage. Extra car parts (not drivetrain), winter tires, misc. household goods, etc. The only heavy item I can think of is a 80 gallon air compressor. For a W.A.G. I'm going to say 3,500 lbs total. Mostly along side and walls.
Here's where it gets interesting. Naturally before I've had a chance to get deep into the research an opportunity to get a Rosboro "X Beam" 3.5"x9.5"x30' Glulam (or 2) for cheap has presented itself. I'm good with an single center post (no wall) to support the glulam, but any more than that is a non-starter.
So should I jump on buying one of these Glulams or is it too weak? :LOL:
Hank11
Tennessee
There are charts for this application. Look at those and then look at the other possibilities on sizing to determine which suits you better.
My initial reaction is that two of the beams you offer might be just fine. But I’m not an engineer and you should not rely on random internet advice.
472scout
back 40
Thanks. Using charts for the joists is simple, but I haven't found anything like that for glulam beams. At least not that I understand.
Using two of the glulams would be fine by me, but to maximize my headeroom I can't have the joists sitting on top of the glulams. I'm thinking I would use hangers to connect the joists to the beam.
Hank11
Tennessee
I'm getting a deal on ones that were ordered, but never used.
this might come down to how much of a deal. If it’s a few hundred dollars to do this in a way that suits you better probably better off doing that.
472scout
back 40
I like that these glulams are only 9.5" tall. Just don't know if one of them would be strong enough.
472scout
back 40
Ok, am I reading this correctly. The 3.5"x9.5" glulam with a 16 ft span can handle 236 plf (pounds per linear ft). 236x16 = 3776. So it can support 3776 lbs?
545_days
Texas
Please don't be insulted by an obvious statement: Don't forget that the glulams also must support the joists, flooring, railing and live loads in addition to whatever your store. 11.6 lbs/ square foot for both live and dead loads sounds really low.
472scout
back 40
If I can ask how did you calculate that? Are you taking into account that the load would also be supported by the back wall?
545_days
Texas
While I am an engineer, I'm not a structural engineer by training or experience, I'm not your engineer, and I turned to the dark side and became a manager over 25 years ago. In other words what I type below is not competent advice
I was assuming 3,500# divided by 300 sq ft on the basis that your 3,500 includes the dead loads from the joists, floor and plywood (which it probably doesn't) I also did not use any safety factor. I do believe that typical loads per square foot for a floor used for storage should be much higher.
Assuming 2x6 floor joists on 16" centers and 3/4" plywood which should be good for a live loads around 50# per sq ft. Your dead weight of materials not including railing is (guessing) 50# per foot. Assuming half the weight of on the live and dead loads is supported by the glulam beam and a 50#/ft^2 live load I would think you would want to support closer to 275#/ft of beam. (10' wide x 50#/ft^2 + 50# per foot for floor joists and plywood = 550 lbs. per foot with half supported by the glulam and half supported by the back wall.)
Of course I completely ignored seismic loads, wind, or any safety factor that a real structural engineer would include. Not because they are not necessary, but because I am not a real structural engineer.
Kaizen
New England
I did a 4x36 mez. Used 2 center posts 6x6 and 2 at the end. Double 2x overlapping each other. I love it. I am glad i built it twice what i thought i needed. I made a mobile elevator which allows me to put all kinds of stuff up there that i never would attempt on a ladder. So overengineer it even if you need another post.
472scout
back 40
I think your material weight might be high, but that is really useful.
A 50 lb live load for 300 sq ft would be 15,000 lbs. According to my math with one center post at 15 ft that 30 ft glulam can handle 8,880 lbs. Of course, it won't be supporting all the weight and I could also sister a 2x10 to it.
For material weight I found some calculators. 28 2"x8"x10' joists (on 12" centers) will weigh approximately 635 lbs and 3/4" plywood decking is 486 lbs.
That said, a 50 lb live load is considered on the low side for storage from what I've just been reading.
CraigStu
Blacksburg, Va
If you are going to use joist hangers be careful about glulams or lvls. Years ago I got a few 2ft cutoffs after a friend built his garage. I thought they's make some great blocks for something, sometime. Then I tried to use my circular saw to cut them. Dang things were HARD. I am not actually sure what they were but to screw something to them I am pretty sure you would need to predrill the holes.
Hank11
Tennessee
Pay attention to this ^^^^^^^ You might want to add a piece of solid two by material to your beam to let you nail the hangers in or you might want to pre-drill and use hanger screws.
have you considered steel mezzanine? the company i work for designs, engineers and installs custom mezzanines for all applications
