12awg submersible "pump" wire
Jdickey03
So I want to wire a back studio, have a family friend whose going to do the electrical but said hed charge just for labor if I get the supplies. My father owns a well drilling business and we have plenty I mean plenty of 12awg submersible pump wire. I see around his shop(which is a old shop) that he used this for electricity. Is this okay to use in my "shop/ studio/man cave"??
J
Jdickey03
Why not? (I know nothing about electrical so please let me know) I assumed 12awg submersible pump wire would be the same as any 12awg?
J
Jdickey03
anyone??? definately not disagreeing with Speedy, I was just curious. I guess a little explanation would help.. about 200' away from my main box, would have to run conduit under my yard to the building.was planning on making it a man cave/work shop kind of thing. (12wide x 38long) I mean realistically i'd like to have more then enough power, like enough power a studio apartment would need, with all the man cave goodies ;) .. sorry extremely unexperienced in the electrical area.
Speedy Petey
NY State
I thought you mean to wire the building. If you meant to run the feed to the building then #12 is not NEARLY enough power. The best you'll get is one 20A circuit. And @ 200' the voltage drop would be severe with that kind of load.
As far as wiring the building, you'd have to run it in conduit everywhere. That will FAR outweigh the cost savings, and blow away the work factor, especially since you don't know anything about electrical work. How would you propose to run conduit inside the whole building?
The pump wire is rated for direct burial, so it has much thicker insulation than typical THHN wire. This will fill conduit much quicker and make it a bit harder to work with.
J
Jdickey03
Haha my first question was about wiring the building with it. But alright sounds good, just was curious why the wire shouldn't be used. The recommended wire for building electricity is romex correct? I might have some out back too but not nearly enough for the whole building
Highbeam
Mt Rainier foothills, WA
First read the wire to find the rating. Is it just NM or is is THWN? Is it UF? We can't tell you what code allows if we don't know the rating.
I've been in plenty of barns where the old well wire is used. I've personally replaced 200 foot lengths of it that failed while being used in a well. Most of it was good so the owner kept it.
J
Jdickey03
The website says its heat resistant and suitable for wet locations. Doesn't that make it a Good wire to use if it can be used in wet and hot locations why can't it be used in a building?
superdel
If you are planning on getting the "cave" inspected then I don't believe the wire is code compliant.
That being said, the short answer is there is nothing wrong with the wire inside the building. 12 gauge wire is rated for 20 amps. Wire the building as if you were using romex. The electrons do not care what the color of the wire is, what the brand name is, or where you got it from. They will travel down a piece of 12 gauge wire just the same.
walrus
Maine
Well wiring is generally one black, one red and one green twisted together. What are you going to use for the grounded conductor? aka "neutral"
J
Jdickey03
Good thing I'm not wiring this thing myself haha. I'm going to use up to code wire if thats what is needed. Just seems weird that a 12awg submersible is not to code as. 12awg romex when they handle the same
Norcal
Submersible pump cable is usually black,red,yellow & newer cable also has a green grounding conductor, & 12 AWG is too small to qualify for being OK to reidentify the conductor, IMO scrap it & use the proceeds to help pay for the proper materials.
Speedy Petey
NY State
It's fine. You're right, it's 12ga so it'll be fine to use.
Good thing you would save ALL that money. :thumbup: :rolleyes:
mm08822
Code requires neutrals to be white (or grey) and grounds to be bare or green, green/yellow. Also a cable has a jacket on it and these are just twisted conductors. Not even code compliant if pulled in conduit. Get get some romex - nm/b. (electrons could care less, but you either want to be code compliant or not.)
ericburns4
You can use the wire that you have for submersible there shouldn’t be any harm in using it.
mm08822
Are you suggesting that it is illegal to pull a jacketed cable in conduit? Better check your source on that one.
Statement has nothing to do with jacketed cable and conduit - but it is all about the color requirements of which this pump cable does not meet.
