14 awg ext cord help ?
sweetk30
finger lakes area upstate ,ny
so i got some old school 14/3 awg cord and want to make a real ext cord over the china cheepy **** .
whats a good amp real world safe rating for it at say 50ft ?
my plan is for a grinder at 9.5amp spec on the unit and a 110 volt welder from hobart 140 model .
if i need to not use it on the welder i am fine with this .
just looking for feedback and advice . and i would be using good ends not the cheepy replacement ends .
sberry
Brethren, Michigan
The welder is a bit different, loses about 8 volts down 50x14 wide open. I can tell, have to adjust the machine a little. The grinder is irrelevent. If I have a choice carry a 12x50 for that type of welding. Unless it's added to a long circuit it doesn't even know it's there. About 3 or 4 v drop.
sberry
Brethren, Michigan
25 cuts the loss in 1/2. It won't effect the welder much. The reason I use 12x50 is it can do the same jobs a 25 can do. I have a 25 but it's just a matter of extra stuff especially portable and 25 is just so short.
Zeke
My experience with 120v welders is that they do not weld very well with any voltage drop. But I haven't use that many 120v models or dual voltage on 120. All my good stuff is inverted based, but the Home Depot Lincoln's and this Hobart are transformer powered. From what I can tell you don't want to starve a transformer voltage wise.
Just because it says it can weld on a 14 ga. extension cord it doesn't mean that's optimal. Use a 12 ga for short runs and a 10 ga for 50' and you will see better performance, IMHO and YMMV.
sberry
Brethren, Michigan
If a guy is welding body steel where the machine is turned down there is a difference. It's easy to turn down. When I test a machine, especially a small one always test at wide open, we wanna see what the top end is.
sberry
Brethren, Michigan
No law says you can't use a better shorter cord but using the listed isn't a national disaster, it works. The hype of loss is a bit dramatic.
It's near obsessive on the forum. There are places it doesn't hurt to upsize, it can be practical, there may be a reason but lots of times it makes it more complicated and costly.
