1951 Shoebox Ford
NRChopshop
here
51 Shoebox Ford. Currently running, driving, and tagged. Straight solid body
98% of all the parts are brand spanking new out of the box. I have reciepts for at least $4000 in just NEW parts. Im forgetting a ton.
ALL parts have less than 450 miles on them
Flathead V8, 3 spd/OD
-Regasketed top end
-NEW Speedway water pumps
-cap/rotor/Plugs/Plug wires/Pertronix coil
-rebuilt carb
-5/8" FoMoCo wide belts
-1949 Radiator, 4 blade fan, and FoMoCo hoses
-motor mounts
-Red's Headers couple to straight heavy gauge exhaust
-OD kickdown switch
-Coker G-78/15s 2-3/4" whites on stock blasted and painted wheels
-7 Circuit Haywire wiring Harness, starter solenoid, horn relay
-Converted to 12v New GM 1-Wire Alternator/Speedway Alt. Bracket and pulley
-gauge voltage reducer
-Turn signal switch, FoMoCo headlight switch, taillamp switch, head lamps, headlamp sockets, taillight sockets, parking/turn signal sockets, and bulbs
-16 Gallon 67 mustang gas tank w/sending unit
-New master cylinder, wheel cylinders, brake lines and hoses
-gas pedal, pedal pads, bumpers
-ALL side, quarter, and wing window rubber/felt/anti-rattlers replaced a month ago
-1950 Hood...zero rot
-1950 grill
-NOS 1950 decklid never installed
-replaced rear gravel guard
-hood bolts, hood bumpers
-firewall grommets, air ducts, etc.
-new trunk seal
-Trunk is ALL new sheetmetal. raised gas tank 5 inches
-Interior is all new.
-Headliner, upholstery, carpet
-Seat frames are in better than excellent shape.
-Sill plates
Suspension
-Firestone Airbags front and rear
-trailing arm rear suspension
-ViAir 450 100% duty cycle compressor, ViAir, 145 psi pressure switch relay, and pressure gauge
-6 3/8" Chrome Airlift Valves
-2 3-gallon Chrome airtanks
-plate, cups, brackets, fittings
-Shocks front and rear
-Upper and Lower Upright and control arm seals
Issues....car needs inner rockers which are super cheap. Motor burns a bit of oil and leaks a bit from the rear main. Smokes from the road draft tube a bit more than it should. Overdrive does not work, however i do have some extra parts and OD solenoid for it. Just not time to fool with it. '50 decklid needs to be mounted. (50 hinges or modify lid to fit 51 hinges). needs minimal body work on some patch panels.
$7700 OBO or possible TRADE
looking for 48-52 F1 PU, 47-55 First Series Chev/GMC PU, or Model A bodies/parts/project cars
Car is titled as a 1950 title and is clear but i will provide a bill of sale stating its a 51 if your state does not use titles.
Any questions PM, email, call.
Thanks, James
[email protected]
240.446.0055
I WILL sell this car without the motor if buyer desires.
