Vet65te
Just getting the final connections done on a Greg Smith 2-post lift and now need to find the right wire/cabling to connect the 220V pump motor to the wall receptacle, distance between the two around 48". The house and garage were built about 4 years ago and the lift location and wall receptacle were all planned from the start so that wall receptacle is 220V connected to a 30A circuit breaker. The lift does not come with a pigtail for that motor and that's what I'm looking for now. The motor data plate is listed as 2HP, 208-230VACm 1 PH. Any suggestions on what kinda wire/cabling to buy?
The wall recep has '4' slots if that helps. Yes, it's obvious I'm not an electrician.
Thanks,
Mike T - Prescott AZ
Thanks,
