It's a NEC violation to use 20A outlets on a 15A circuit. Safety issue???... 20A 120V outlets are different than 15A 120V outlets simply because you can plug in an appliance that has a 20A plug.
Yes, a safety issue..........exactly as I stated. I know the difference.
Running a 20am load on a 15 amp circuit qualifies as a safety issue in my book, and a 20a plug can prevent someone from doing this.
That is interesting that the contacts on the 15a receptacle are the same. They can make one body for both and snap on the face plate that is needed for the finished product being made.
The push in wiring vs. screw down is a great point. I will not use the push in style as I have seen too many of them fail. The back wire style with a screw down connection are a great compromise, in my opinion. The traditional side wire/screw down are fine. After installing hundreds of receptacles, you get good at bending a hook on the end of the wires.
I have worked on customers' animal dryers that have 125v 20a plugs on the cord..........molded ends and built that way. The Lamb motors will easily pull 9amps each at 122-123v on average and all of the decent dryers use two vacuum cleaner motors. I want to say it was an edemco brand dryer and the company went out of business. Double K dryers use a 15a 125v plug but still have two motors. Our business is an authorized repair center for Double K but we work on most brands of grooming equipment. Many customers have problems with overloading circuits in their shops due to running multiple (sometimes 4-5) force dryers at one time. Even a 20a receptacle would not help here, unless they had only a single per breaker and didn't use the duplex receptacles. With that said, 125v 20a plugs are not all that common but they do exist. Some may even get cut off and replaced with 15a versions when the customer finds they don't have the right receptacles.
