Nch209
Hello,
Long time member, but not a electrical pro, so any answer would be wonderful.
Issue-
Proper Wiring for air compressor.
Unit- Kobalt 2hp/ 30 gallon 2 stage air compressor. https://www.lowes.com/pd/Kobalt-KOB...e-Electric-Vertical-Air-Compressor/1000528965
...from the reviews people are using a nema 6-15 plug... unsure of wiring.
Current Wiring- Without looking, pretty sure its 30amp breaker on 10/2 wire with NEMA 6-30r plug. Garage is finished/drywalled and painted, and pulling new wire is not an option, and not running on outside of wall in conduit.
My question is, as
dumb
as it may sound--- burn me for asking, lol.... is, what happens (theoretically) if I ran above compressor on the 30amp circuit with a 6-30r plug. My run is about 55 feet from breaker box.
The reason I ask is because I would ideally like to put compressor on my second floor as I am already- 1. Wired for it (use a space heater up there in winter with that plug setup---- but would use same outlet for compressor--- not both at same time, and have air lines up there dropping throughout the bottom level. Would like just a small compressor out of the way-- out of sight and much quieter...
Any way to make the above work compressor work on a 30amp 10/2 wire setup or am I asking for
trouble
(These units can run off of 110 as well, but seems like guys are kicking breakers and say 220 is the better setup.)
Hope this makes sense, and someone can help me out some. Sorry, no name plate info from motor as I am trying to figure this out before I purchase.
Thanks Much!
nch209
Issue-
Proper Wiring for air compressor.Unit- Kobalt 2hp/ 30 gallon 2 stage air compressor. https://www.lowes.com/pd/Kobalt-KOB...e-Electric-Vertical-Air-Compressor/1000528965
My question is, as
trouble
.(These units can run off of 110 as well, but seems like guys are kicking breakers and say 220 is the better setup.)
Thanks Much!
nch209
