nissan_crawler
Well, I bought a drag harrow from TSC to do my driveway, but...although it worked great, it was less than ideal to use.
A. I needed it to follow the tractor better in turns to get the outer edges of the driveway.
B. I needed to be able to lift it up at the end of the driveway, so I don't drag all the gravel onto the street.
C. When using it with the tines down, and it fills up with grass/sticks/etc., it ***** to have to pull over, jackknife the tractor, lift the harrow by hand and shake it, then move it over so it doesn't go back in the pile of trash you shook out.
D. I want to see how well it works at ripping out some ivy on my property, but can't do that without being able to back up to it, set it down, then go forward, plus again wanting to be able to lift it to clean it.
So...I dug in the old scrap metal bin, made a trip to TSC for some Cat. 0 pins and chain...and came up with this:
Lifted:
The high frame and chains still allow it to float like it needs to. It raises 12-18" or so.
Lifted:
