tabosko
Hello all!
I have a walk in closet that has to light switches on each side that control the same light.
Goal: I want to convert one switch to a switch/outlet combo single pole as I have no use for the other switch. it will simply be used as a pass thru. I need continuous power to the outlet.
Problem: From my understanding a 3way setup has one black "hot" wire from the breaker. this goes into one switch that breaks off into 2 travelers to the other switch which then goes out that switch to a load to the light..
My Voltage detector is reading a "hot" wire from each switch... the light that I'm swapping has a red wire from the wall thats hot (I previously thought this was the load) AND in the same box there is a black wire thats hot as well thats from the other switch. In fact I can disconnect every wire in this box and still control the light from the other switch. I have included a diagram of the old switch and how I have the current switch hooked up (2 black wires left off as I dont where to put them.) NOTE: the fin is broken. Why would there need to be 2 hot wires from the breaker?
