6 Year Shed
Fleege
Hey all,
I just want to start by broadly thanking this site and the members. I grew up around the garage and am fortunate enough to have a Midwestern background - complete with the Dad who is the go-to guy for fixing about anything - but I personally had never built anything substantial until I started my “6 Year Shed” project. I spent a ton of time, especially in the planning stages, watching your builds and stealing your ideas
When my wife and I moved ~5 years ago, we knew we wanted a property that gave us some elbow room from the neighbors and would allow me to SLOWLY put up the shop. I call it the “6 Year Shed” because a) I expect it to take 6 years and b) I keep hoping if it’s called a “shed,” maybe I’ll get the green light to build another one in year 7…
Although I’ve sent messages to many members and was on the site long before I officially joined, this is my first post so it looks like I’ll need to tell a 5-post-long-story before I can get into the build…
F
Fleege
Considering I’d never so much as built a wall before; this whole idea was probably just a little bit nuts. I briefly toyed with the idea of just hiring it out, but ultimately knew it was something I wanted to actually build.
There were months when no progress was made. Even summer months – which is always extra annoying. Outside of the full time gig and the part time gig, I joined the FD and have been working on reclaiming our property which had just become overgrown over the past decades. I think we’re at ~75 trees (say 8” or larger) that we’ve had to take down so far.
F
Fleege
So, after we settled on a location (turns out not everybody thinks the middle of the front yard is the ideal spot??!), it was time to clear the land and actually settle on the footprint of the shed.
Key purchases to get this far:
  • Husqvarna 455 Rancher (H47 chain really does make quick work of most things)
  • 1980s Deere 675b Skid Steer with backhoe attachment. (Fantastically embarrassing story of how I limped that thing home)
F
Fleege
If overthinking was a sport, I’d be a staple on ESPN. The decision on size, orientation, construction type, etc. took me just slightly longer than eternity. But, the shed ended up:
  • Stick frame (2x6s)
  • 40’ x 64’
  • monolithic slab
  • 10’ walls sitting on top of a 5” concrete “curb”
  • Trusses 2’ OC; sheathed + metal (overbuilding will become a theme); combination of attic and scissor trusses
  • Walls 16” OC sheathed + metal
F
Fleege
I started clearing trees and prepping the pad in the summer of '16. We don't have much elevation change, so I added a piped/graveled french drain around the perimeter - sloped to the C/D corner and then runs further to a dry well. Ton of sand out here, so there's a significant gravel base. I think we put 10 miles on the plate compactor; ran it 2x over every ~3in of gravel.
Under the pad: added a couple drain lines, stubbed out PVC for low voltage runs, PVC for power (which I eventually didn't use), and sunk a frost free hydrant for when I'd finally get around to running water out to the shed.
(fast forward to 2020: I finally got low voltage and water within the past month. 2020 me was cursing at the 2016-me for just "filling in the hole for these stub outs; I'll figure out how to deal with it later.")
F
Fleege
Got the pad poured in late Fall (2016).
  • Homemade (clearly! :lol:) forms (Perimeter trench is 2'+ by 2'+ and then sloped toward the center of the pad)
  • Rigid insulation
  • vapor barrier
  • ~1 mile of #5 rebar (+infinite number of chairs and ties)
  • 180 tons of concrete (finishing the concrete is the only things I've hired out)
I was generally happy with the layout, construction, and even the spacing of the anchor bolts (which are 24" long!). Not thinking about relief cuts in advance made things more difficult 3 days later with a circular saw... :Violent:
F
Fleege
2017 was spent framing, decking, and taking some time off after choosing the express route off the roof...:Help:
F
Fleege
And 2020 was siding, trim, garage doors, power, and water. I could actually start using the space for projects; instead of just as a project itself! Also started framing/finishing the back 1/3 as a mancave...
thammel
Maryland
Yep; When holding down a full time job, it took me years to finish. The garage passed inspection in 2010. Just in early 2020 I finished everything. Whew!!!
F
Fleege
I'm coming up on 3 years so I can certainly relate to this project.
Glad to hear it's not just me! Now that I've made a little progress on the mancave portion of the build; I think I've spent more time in the shed the last two weeks....and made zero progress!
F
Fleege
Congrats! I'll have to check out your build. I'm not sure I'll ever be "finished," but looking forward to the day when I have to think about what project is next!
jblnut
In the Middle of MN
That is a really nice looking shop. I really like the scissor trusses with the attic room. Any plans for it ?? I put a room above the office/mech room in my farm shop for the little people to hang out in and it was a fantastic decision. They're out here often and can help when they want and go play upstairs in the relative quiet when they want as well.
That is a pretty sweet Deere skiddy you've got there. I had a Sperry New Holland L325 for a while and that looks to be it's big brother the L775 (only in a green dress) if I'm not mistaken. Having a backhoe for it is something of a rarity !!
We had big plans of fixing/maintaining lots of things in the shop this winter but the shop itself has been a project so not much has been done. It's been really nice to have done the few little things that have had time for though !!
