allsixofus
I'm proposing to build a detached garage (10' from house = a 50 - 55' wire run) and installing a 60 A sub-panel (from a 200 A main in the house). I'm anticipating being required to have a shut-off ("Main" switch) in the sub-panel. Having as yet to find a 60 A box with a "shut-off" or "Main" switch, factory installed (and with a min. capacity of 6 circuits), what options do I have? I've found a GE 125 Main Lug box (with a capacity of 8 - 16 circuits) with the capability ? to "convert to a Main". How do I achieve that? Can I just insert a 60 A breaker into top slot of the sub and feed that with the wire (6-6-6 Cu w an 8 ground, THHN, direct burial approved) coming from my Main. Is that "back-feeding"? and is that NEC approved? There will be a 60 A breaker off the Main panel feeding the sub-panel. And while I'm here, the wire has a 75 Celsius wet, 90 Celsius dry temp. rating but I've noticed that these boxes request 60 and 75. Are there boxes out there with the 90 C rating? PS: I'm only planning on having 3-5 circuits from the sub-panel.
