7" Diamabrush tool loading up
mikec35
NC
I'm removing polyurea from an 8 x 15 area and it's loading up the blades after you cover roughly a 4x4 section. Does this normally happen with this tool? How do you clean the blades? I took the Diamabrush off and used a wire brush to clean- kind of a pain in the **** to do this every few feet. Any advice? Thanks
LegacyIndustrial
deerfield, IL
PolyAspartic gets quite a foot-hold and is tough. Try adjusting the speed, go slower.
You may be melting the coating onto the blades by going too fast.
mikec35
NC
Thanks for the advice Scotty. I was using a 6000 rpm grinder that burned up on me yesterday. I found and repaired a 4800 rpm grinder that I had and will try once I receive the new Diamabrush shroud I just ordered from Legacy (hopefully I will receive by Friday so I can complete the project this weekend.). It's hard to find a low/variable speed 7 inch grinder.
