MattMotoWeldGarage
- Joined
- Jan 1, 2025
- Messages
- 18
Hi, I have a Campbell Hausfeld HU5000000 air compressor which is not pressurizing. It's a 3.8 cfm @ 90 psi, 8 gallon number.
I took it apart a bit to see what's up. The motor itself works and it is pumping out air. So I don't think the issue is the motor but after.
I don't think the tank is leaking but it could be hard to tell. The drain valve is closed and the relief valve is closed too.
Any thoughts on what might be going on? I guess the main regulator could be bad but would that prevent it from building pressure?
Thanks!
Thanks!
