A few trammels and beam compasses
royce
fairbanks ak
Whoops, pics did not show
I saw on another thread, a bunch of trammels.
I thought I would post a few other styles here.
Royce
Mintgrun
Kingston, Wa.
Very nice collection. Thank you for sharing those photos.
I have three of those styles and am very fond of them.
I guess I don't need to run up and snap photos : )
Tom
paulm12
NW Chicago 'burbs
Thanks Royce for posting.
Hmm. I wonder if I have passed over the ones that attach to the wooden rulers in the past. Now I have another item to look for at the old garage sales.
R
royce
fairbanks ak
Tom
Thanks Tom,
I'd like to see pics of yours.
Royce
R
royce
fairbanks ak
Very useful measuring tool..... it's funny you see them so rarely.
Very few things I seem to build that I don't use a trammel on, either to swing a arc or transfer dimensions or at the very least, draw a square corner on the floor to start the layout of a project.
Royce
R
royce
fairbanks ak
I seem to reach for those first, they have multiple holders for points, carpenter pencil, soapstone or regular pencil.
The sectional aluminum beam one, has a razor, which is handy for a fine line on wood or for cutting gaskets.
Thanks
Royce
Mintgrun
Kingston, Wa.
Royce, here are some photos of the few that I have.
This Precision set was made in Germany. I purchased it on eBay several years ago and polished one piece, but stopped there : /
Tom
jimreed2160
Tallahassee FL
Trammels? Yes, I do have a few sets.
If you want to see some in action, I invite you to visit the Woodworking 101 thread over in General Tool Discussion. There are quite a few postings on trammels and their use in woodworking. The thread is very active and full of project pictures and woodworking lore.
R
royce
fairbanks ak
Right angle layout with a trammel
While a square corner can achieved with 3-4-5 or the square root of 2, I find doing it with a trammel easier.
First layout a baseline.
Set the trammel at whatever radius suits the job, A-B, swing a short arc across baseline both ways from A to B
Now set the trammel about 1/3 longer than the A-B radius.
Swing the short arc B-C from both ends.
Now, draw a line from A to C
Presto, square corner, guarantied.
I probably did a poor job of explaining this and is elementary for some,but maybe some can use it.
I'll try to show a square inscribed in a circle tomorrow.
Royce
Mintgrun
Kingston, Wa.
A similar approach can also bisect any angle.
I often find it useful to divide a circle into sixths, for hole layout on 'round things'.
Walk the trammel around the circle, set at the radius, and it will get you there.
I am eager to see the circle around a square.
Tom
R
royce
fairbanks ak
Tom
Good point mintgrun, with a hexagon the radius is equal to the length of sides.
Royce
R
royce
fairbanks ak
Square inscribed in a circle
So, to lay out the square, take the B-C radius and swing the intersecting arcs opposite of the first ones.
Then, draw a line from A to C
Now, scribe the A-B radius all the way around to form the circle.
Then, draw the lines where the perpendicular lines cross the circle.
In the second pic only half of the square is shown.
Presto, square inscribed in a circle.
Next up, octagon inscribed in a circle.
Royce
R
royce
fairbanks ak
Octagon inscribed in a circle
This is done similar to doing a square.
Set the trammel to a little bigger than 1/2 the distance between B-C and swing a short arc from B-D and C-D
Everything else is the same as doing a square.
If this is not clear, I can explain more.
The left side of the pic shows it.
Next up, triangle inscribed in a circle.
Royce
drivesitfar
Royce: thank you for trying to teach us how to use a Trammel. i only knew they existed a few days before you started this thread when Jim posted his collection on the Woodworking 101 thread.
i'll keep trying to understand what you are teaching us and first of all i have to see if i own a pair of Trammels or i'll have to find or buy some.
hope you were able to get your addition framed in before the bad weather hit.
HAPPY THANKSGIVING
HenryAZ
MEMBER EMERITUS
South Congress AZ
Octagon inscribed in a circle.
Construct a line perpendicular to a line, using compass or trammels (an X-Y axis). Also using trammels or compass, bisect each 90 degree angle. Strike your desired circle and then connect the 8 points where they intersect the circle.
Mintgrun
Kingston, Wa.
The pentagon is a tricky one!
I found how-to-do-it on a puzzles page, but did not read the answer... yet.
I would like to think I'd figure it out, but have not put the effort in.
R
royce
fairbanks ak
Mintgrun,
I've not laid out a pentagon, so I googled it and there seems to be quite a few steps.
But a man could cheat and step it off a few times and get it!
Royce
R
royce
fairbanks ak
Triangle inscribed in a circle
For a triangle, lay out baseline and perpendicular line.
Set trammel for radius A-B and scribe circle.
Leave radius adjusted to A-B radius and swing short arc from B-C both ways. Then connect a line from C to C.
Finally connect lines C-D both ways
Royce
R
royce
fairbanks ak
Hexagon inscribed in a circle
As Mintgrun pointed out in a earlier post, the radius on a hex is the same as the length of sides.
So it is simple to swing a short arc from the base line both ways and connect the dots.
Royce
R
royce
fairbanks ak
Why do you think they carry broomsticks?
Great thread!
2ool,
There has to be a punch line there somewhere?
Some of the beauty of trammels is you don't have a lot of math or constants to remember.
With that said, another way to layout a pentagon is with a little triangulation and trigonometry.
A pentagon is 360 degrees divided by 5, that equals 72 degrees.
Split that and you have 36 degrees.
In this example let us use a 6" radius
To get the length of the side opposite, take the sine of 36 x 6"
Multiply that x 2 to get the length of side of the pentagon.
Royce
R
royce
fairbanks ak
Trammel of archimedes
This is a fun one I cobbed together for drawing ellipses
Royce
R
royce
fairbanks ak
I was suggesting witches would use their broomsticks for the beam. Kinda out there, I know.
Got it now 2ool,
I'm a little slow on the take!
Here is a wild one, made by lufkin, for laying out round fittings.
