A question for small engine mechanics
rust in the eye
Chicagoland
I recently serviced a Honda snowthrower powered by a GC160 engine.
While reinstalling the cover over the auger drive belt I set the machine on its side which oriented the engine with the recoil start down.
Those in the know probably know what happened, the engine puked a good portion of its just refilled crankcase on the floor. Seemed that is was coming from behind the recoil start.
My question is where did the oil come out from? How, where, is the crankcase vented on these things?
Firebrick43
West central Indiana
There's a reed valve and a breather tube leading into the carb, possible that that tube may have got knocked off.
Or it could have ran thru the breather and breather tube and out the mouth of the carb.
The breather is below the carb on the side of the block.
Is the air filter soaked in oil?
mreisner
North of Detroit
Yeah that's what I meant, instead of having like a PCV valve the Breather has a reed valve
R
rust in the eye
Chicagoland
Thanks, guys. It's a snow thrower so no air filter and the engine lives under coverings.
If I get ambitious I'll remove the coverings again to look for that breather. I do remember a tube hanging down somewhere but not connected to the carburetor, it DID have one for a fuel bowl drain. There was also another I didn't pay much attention to, must have been it. Meanwhile I now know better than to tip this on it's side. I tip my mower's B&S vert shaft all the time to sharpen blades with no consequences. Lesson learned.
